Bluetooth RSM for 7550e
blaketexas081
Richardson, TX
Scanning the forum, not seeing any threads on a Bluetooth remote speaker mic that works with the 7550e. An option that comes up on a search is PMMN4127 (WM500), but the more I read, the more uncertain I am about real compatibility.
Anyone have operating experience with the WM500 or some other variant?
Thanks in advance...
Blake
K2NEC
5F6
The RLN6562 is the BT mic for the XPR series
blaketexas081
Richardson, TX
Thanks for the reply. I've seen that one referenced, as well. As you alluded, "proud" is a practical reference to /\/\. Have you happened to pair and use a 6562 with a 7550e? At 2.5 hunner bucks, I gotta think long and hard... sure is a steep climb outta the "cheap" radio and accy catagory. :)
K2NEC
5F6
I personally haven't but my friend had one for months that he used with his 7550e
Firmware 2.09 if its relevant
K2NEC
5F6
PMMN4096 is the mic part number, RLN6562 is the kit number which includes the charger
n3obl
ØAES-1024
PA
Also if you look for RLN6562 or PMMN4096 on the used market make sure it doesnt have the blue dot. Same mic with different firmware for touch pairing to APX (mission critical) vs (Operations Critical).
blaketexas081
Richardson, TX
Good to know. Wasn't sure about the blue-dot pairing v. "manual" pairing. Love how /\/\ segments XPR and APX for accessories. Great business strategy, but doesn't endear them to some of their users. I carry an APX and an XPR for different tasks/duties... had hoped I could do a one RSM for both (clearly, not at the same time), but... whatever.
K2NEC
5F6
I believe there was a model out there that *did* do both, I cannot recall which model it was though
n3obl
ØAES-1024
PA
the Ops critical can pair to APX if you use CPS to allow legacy pairing in the radio.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Be careful as there are at least 3 options: First the APX public safety with the blue dot, then the xpr 7000 version, then the new one that works with the R7.
TT
