Border Patrol - STX area
rattlerbb01
TX/LA Database Admin
Boerne, Texas
Here's my little contribution. I'm currently in Donna, TX and I'm hearing quite a bit of chatter (2-3x a day) on CBP channel 169.887500 CBP Weslaco 2. It's quite sporadic and when I've noticed it, its general transmissions like "I'm going to gate 2", etc, etc. Also, I think I'm only hearing one side of the convo.
Thanks for the info. They are heavily encrypted but not fully. Some units just don’t flip the switch for whatever reason. Helicopters are almost always clear as a rule of thumb. Every now and then you’ll hear both sides.
ecps92
Taxachusetts
that would be for BP, CBP (aka Customs) has their own nets
I assume you are reporting the NAC of $A30 for Weslaco??
As to one side, maybe the other person is not answering
ecps92
Taxachusetts
Well, I have to say that the tropo conditions in the coastal area of South TX combined with the reuse of several frequencies has made this a lot of fun, but I have some new findings after travelling down to the Sarita checkpoint and back today:
I also got 170.4375 (C10) going north out of Corpus around Mathis medium strength.
Still trying to locate 171.7625 (A90). It is stronger between Corpus and George West but I haven't gotten close enough to it to actually locate it.
172.4125 (A30) is going to be a Weslaco Station tower somewhere between Encino and Raymondville if I had to make an educated guess. The Valley is going to take days to sort out when I have the time and a reason to be that far down there.
There is an FBI Net of three repeaters also down in the area, 170.6750 (167), 170.8375 (167) and 171.9875 (167).
I am thinking National Seashore is using 170.9125 (864 NAC), although it could be anything else Federal as well, but it was pretty strong through Kingsville down to Riviera.
170.4375 C10 should be ICE form CC for their East Net
$864 has generally been know for bring the USM, but no reports on 170.9125 being found in TX
and NPS for Padre Island had been using $4FE on 164.8000, 171.1625 and 172.4625
rattlerbb01
Boerne, Texas
New find in Carrizo Springs, same site as the 166.9875 CBP repeater:
171.6125 NAC 864 - probably USMS based on NAC
rattlerbb01
Boerne, Texas
One night in Laredo is all I needed. Here’s what I’ve got even though I don’t have the physical location nailed down for the towers actually in Laredo proper yet:
Laredo North Station:
170.3750 (301) / 164.7375 (325) - Botines
173.0625 (301) / 162.7500 (325) - Botines
Laredo West Station:
169.6375 (301) / 162.2875 (325) - Mines Rd Apache Ranch
172.0625 (301) / 165.2375 (325) - Laredo Northwest?
Laredo South Station:
172.3000 (301) / 163.5000 (325) - Laredo
173.0500 (301) / 163.8500 (325) - Laredo
There are also repeaters on 172.100 which appears to be in Botines, and 170.100 which appears to be further south or east in Laredo. Both 301 NAC. The identified ones above came from analyzing unit IDs, data traffic, locations of input frequency strength. None of the towers are synced up with each other like other areas of the state so each repeater is standalone.
rattlerbb01
Boerne, Texas
172.0625 is also on the Botines tower. Laredo West Station.
4D5 3.95 Laredo is close to Calton Rd near the city of Laredo and AEP trunk towers. Very strong signal just don’t know which one yet. They are less than 100 yards apart so really splitting hairs to guess any further.
4D5 3.111 Encinal is on a ATC cell tower just south of the I-35 checkpoint.
4D5 3.112 Devine is on Crown Castle tower on CR 777 1 mile east of I-35.
fire1429
texas
A90 Net - 171.3250 - Calallen/Robstown/Violet (basically NW Corpus) - can't pinpoint this tower but it is booming without an antenna at the 69E/37 split
A90 Net - 172.2375 - Corpus Christi downtown/shoreline area tower - again...can't pinpoint just yet but it is booming in that area
A90 Net - 172.4125 - Confirmed on Kingsville Tower
A90 Net - 171.6625 - Confirmed on Riviera Tower by dollar general. Previously thought to be in Falfurrias area.
A80 Net - 170.9875 - Confirmed on Riviera Tower by dollar general. Previously thought to be in Falfurrias area.
A70 Net - 170.3375 - Confirmed on Riviera Tower by dollar general. Previously thought to be in Benavides area. (this one has me scratching my head because it was so strong from Benavides a week ago)
A60 Net - 172.2625 - Confirmed on Armstrong Tower (about 5-6 miles east of Armstrong on King Ranch coastal pasture)
I have so many questions I’m interested in what your approach is to identify these systems. Can you explain? I’m from the RGV also and could help if I knew what I was doing.
Also correct me if I’m wrong but these are VHF trunking systems? I’m familiar with programming 800 mhz trunking systems but how do you program a VHF trunking system? This might not be the correct place for that question but thought I’d ask.
rattlerbb01
Boerne, Texas
It would be a novel to type out everything I’ve done to figure out Federal VHF. Everything is still conventional and P25 at this time. Trunking is 100% easier and it does look like they will eventually be going that route with the wide area system that is still being installed and tested.
So from the beginning….
I never truly bothered with federal until this year. Always assumed full ENC so why bother. But I tried nonetheless with my SDR and DSD Plus program to see which frequencies were used in the areas I was in around Carrizo Springs. I was shocked by how much non-ENC there really is. So that said, here’s how I do it:
DSD/FMP24 lets you view about 2.4 MHz of spectrum in the waterfall window, making it easy to see transmissions and narrow down on them. I have found just about every transmitter with this method. Feds make it easy to find the frequencies with P25 conventional on VHF because the units in the field have frequent data bursts and possibly roaming beacons on wide area networks with multiple repeaters. These even give you the NAC for the frequency in use. There may not be any voice for hours or days sometimes but the data still goes on. You can also see when there are multiple transmitters making up a network because they will key up and broadcast the same data simultaneously.
Now for the RGV where you are, look back a few posts and you’ll see that they make it easy to discover what a particular site is used for. For instance if a frequency has a NAC of A10, it’s from the CBP Rio Grande City Station, A30 is Weslaco, and so on. B21 and other B’s appear to be bridges. C’s are in the outlying areas away from the border like Beeville or Victoria.
My main focus is trying to narrow down where the individual transmitters are located. There are 6 towers for the A10 RGC Station network, but I want to get close enough to verify which one is Roma, which one is RGC, which one is San Ysidro, etc. makes the database cleaner and more accurate.
fire1429
texas
I would like to say that it’s very impressive the work you’re doing. I honestly never got around to purchasing the SDR equipment, I had seen it used to decode 800mhz p25 control channels. But hadn’t taken a deep dive into that realm. I have used uni Trunker, but thanks for reigniting my interest in SDR/DSD.
madrabbitt
NM
If this was 1980 I would say it was probably BP geophone sensors.
I don't know if what they have now still uses low speed VHF high band data.
CBP's isolatated mesh telemetry ground sensors in the southern NM region include VHF data.
The sensors are either mid to upper 800, or ISM 900 to the controller, but the controllers are transmitting the data streams on VHF.
This system dates back to 2013, replacing the single node ones deployed since 2005.
No idea what the newer advanced generation networks use though.
rattlerbb01
Boerne, Texas
I have been guessing that there are sensors making up some of the data on these VHF repeaters but no way to really tell. I’ve got a few hours of audio from the Laredo sites I will listen to at some point. I have listened to a little and I know that they have a camera operator that is reviewing cameras all over the Laredo South riverside for agents in the field. No talk about sensors so far that I’ve heard.
nd5y
Wichita Falls, TX
I copied this system for the first time this morning.
The site I copied isn't in the db.
Unknown location. Might not even be in Texas.
Customs & Border Protection BEE00-4D5
Site 003-118
NAC 4D2
169.9125C
No alt CCs, no neighbors.
More info at
It's showing neighbors now and one isn't in the DB. I'm not sure if it was logged and reported in this thread.
rattlerbb01
Boerne, Texas
I'll update 4D5. It's been quiet lately, nothing new to report. I was actually right by the US 277 checkpoint for a week or so on our last project and confirmed that they use the Carrizo Springs D13 repeater 166.9875 and Tac 1 166.7375. Pretty good signal on D9, D10 and D11 and the Eagle Pass 4D5 site, and a new site showing up as a neighbor to Eagle Pass: 3.114 on 173.7875.
WRUL486
I've found quite a bit of newer Border Patrol frequencies in the area along the middle Rio Grande. Most of the frequencies have P25 databursts using the same NAC as voice, but not sure if it for vehicle location, traffic sensors, or what since DSD doesn't decode it. Lots of talk in the clear surprisingly. Aircraft units, transport units, dispatchers and clearly identified Texas DPS units also coordinating with CBP. Still plenty of encryption though. Almost all CBP patrol units seem to be ENC.
169.9375 NAC 315 - Heard pretty strong from NW Webb Co (Briscoe Ranch/Mines Rd area)
169.6375 NAC 301 - Also heard from NW Webb Co but weaker, stronger on north end of ranch so probably West Dimmit area
172.3000 Didn't write down NAC - Heard fairly strong from Catarina
166.9875 NAC 310 - Very busy Carrizo Springs tower
172.8625 NAC 301 - Crystal City medium strength
169.1375 NAC 290 - Very busy LaPryor tower
170.1500 NAC 294 - Uvalde area, but not in Uvalde proper
168.7625 NAC 289 - weaker signal from Uvalde but decodes okay
166.7375 NAC 314 - Uvalde Tower
167.6875 NAC 167 - FBI Uvalde?
This is in addition to the new towers for the 4D5 system I found in that thread./
Have any of you discovered the Rx / Tx w/ NAC for cbp marine and air unit near Laredo area? Ive seen some posting about it but not fully confirmed.
rattlerbb01
Boerne, Texas
I’ve heard the CBP Air-Air AM channel listed on page 1 there, but that’s it for the Air and Marine for me. I’ve had those and all the ICE national Tacs programmed in for months.
rattlerbb01
Boerne, Texas
Been quiet for a while, but I confirmed that 169.8875 NAC 304 is Laredo Sector - Devine. Confirmed it’s on the same tower as 4D5 site 3.112. I haven’t heard 171.1875 Somerset in a long time and suspect that Devine may have replaced it.
I also noticed newer antennas mounted about 3/4 up the old El Indio tower towards the end of FM 1021 just south of the Aerostat blimp base. Will try and keep a listen out for anything new from there.
Still haven’t found where 173.7875 control channel is located either. Does not appear to be anywhere along old Mines Road, so will just have to look toward maybe Bracketville, Spofford, Rocksprings, etc.
rattlerbb01
Boerne, Texas
173.950 NAC 309 is coming in within Maverick County from the El Indio area pretty good now, seems to be about the same signal strength as the Eagle Pass repeaters. Not enough time to find out any more info on it yet, and it was all encrypted. The El Indio tower is still silent but there are definitely 4 nice newer antennas mounted on the upper 3/4 of the tower. It is all Carrizo Springs Station area of assignment down there, and I've yet to hear any of the D9-D12 mobiles light up my scanner, but from Carrizo-El Indio-Mines Rd all the way down 164.275 NAC 307 which is D13 mobile is highly active at all times. The Tordillo tower which I am 1/4 mile from currently is busy all the time on 169.9375 NAC 315 and there is a lot of foot traffic right now. Don't stop for anyone is our rule when we hit Old Mines Rd......
STARRMED28
In rio grande city i pick up BP frequencies but they are encrypted
Frequencies:
170.9875 NAC A10
171.6625 NAC A12
171.9625 NAC A10
169.8875 NAC A10
rattlerbb01
Boerne, Texas
Frequencies:
170.9875 NAC A10
171.6625 NAC A12
171.9625 NAC A10
169.8875 NAC A10
Yes, the A10 NACs are a network of 5-6 (I can’t remember exactly) towers around Starr and western Hidalgo counties that comprise the Rio Grande City Station. The A11, A12 towers have appeared to be standalone sites for local traffic, such as a city tactical repeater, HQ repeater, or maybe bridges or detention centers. With all the ENC it is tough to know exactly, that’s why it takes months of monitoring to catch the clear guys time to time that let you know what the channel is for.
