Bradley Fire
scanner404
CT
For some reason I'm hearing the Bradley Fire Dept. on 159.900 as well as on their 453.500 frequency. I don't see the 159.900 on the BDL frequency page here on radio reference... Bradley International Airport (BDL) Scanner Frequencies and Radio Frequency Reference
Any idea's why they're simulcasted on that frequency? I had that programmed as Winchester's Fire-Ground, but was caught off guard when they started saying "Bradley fire respond to terminal...."
PJH
They operate on UHF unless someone somewhere has a patch running...which shouldn't be happening.
How close to the airport are you and what scanner are you using? Some scanner have been known to do goofy things.
cg
Connecticut
It is a patch over to VHF set up by the airport. I believe it was done for the CTANG FD
159.9000 206.5
chris
PJH
Air guard fire has bdl radios in their trucks...ill have to make a call or two and see what's going on.
N1TGE
CT
Windsor Locks is VHF. Maybe it's for interoperability?
PJH
Wlfd has UHF radios for the airport as well.
scanner404
CT
The call I heard was for some lady who injured her foot. They said Windsor Locks was notified, but I heard only Bradley Fire officers and dispatch talking. I live about 6.5 miles from the airport, so I guess it could just be interference. I have a RS Pro-164 with a pretty good external VHF antenna. Any confirmations on the "patch over to VHF set up by the airport" theory?
scanningisfun
It's definitely a patch.
Jacob
PJH
Guys, from what I have been told, this is something that Keith Victor setup with his "Alarm Room" services (which I am not sure what that does).
The freq comes back to his license in the industrial/business pool and not the public safety pool. License of WPHB880.
For those who have submitted this as a BDL channel, I am putting a hold on this as it appears that it is not a BDL channel. If the Air Guard needed a VHF channel they would have had it assigned to them under NITA in the federal band and not in the general specturm (under most circumstances).
xplorer417
AGAWAM MASSACHUSETTS
bdl 159.900
hi guys remember they moved the tower a little bit ago I think its a rptr patch into the uhf rptr I know how things work also it.might be for tsa to.listen to on there portables if there is a incident in the airport.
CT
Central190,
I had to re-read this a few times with my grandfather's glasses. (He is asleep) Still, I really wish I knew what the heck you were talking about.
What's your point? Plain English Please?
xplorer417
I am saying they moved the tower and they also changed frequencies many.years ago and they needed a link from.the troop w dispatch to the tower instead of using phone lines.
