Brampton Transit
docu
Need to hear brampton transit again anybody know what the system is that they switched to and what freqs and ids there using please help. :(
docu
They are not on peel trunk system I heard that they are on ltr 900 system maybe someone could post the freqs and ids please.
poppys780bc
Brampton Transit new frequencies
I was out around Brampton today with my scanner. I started scanning the frequencies from 800 to 900mhz. I found 2 new Brampton Transit frequencies.They are 807.0250 and 820.0250. I will keep trying for others. I heard that there were up to 10 new ones. When I find more I will post them. If any others find any please post too.
tonsoffun
Senior Moderator
Central Ontario
Re: Brampton Transit new frequencies
Are you sure about those frequencies, last I heard was there where on a 900mhz system including some others.
Try these systems
http://www.radioreference.com/modules.php?name=TRSDB&sid=2493
http://www.radioreference.com/modules.php?name=TRSDB&sid=2267
DaveH
Ottawa, Ont.
I also scratch my head a bit. The 800MHz band plan has repeater inputs 806-824MHz, for outputs in the 851-869MHz range. If you are hearing inputs, check up 45MHz i.e. 852.025 and 865.025. This seems unlikely and TAFL shows none of these frequencies. It may be some sort of image from the 900MHz band. Are you in fact using a BC780XLT?
Dave
poppys780bc
Brampton Transit Radio System
Yes I am sure about those Frequencies as I have programed them into my scanner and it is picking BT up.
I also heard, it was to be a 900mhz LTR system,so I dont know what is going on only that these are the ones that I found as I was searching today.I am using a BC796D scanner.I have been scanning 900mhz with no luck.I will keep trying 900mhzas well as the 800 .Someone out there must know something. Do you live in Brampton? Do you work in Brampton??
maxtracs
brampton transit
i Know the frequency for brampton transit YES they are in the 900 LTR system BUT i do not know the ID they are useing I will post the frequency here tomorrow because it is programed in my truck i will tell you how i am getting it
transitman
Back of the Bus
Brampton Transit Frequencies
Information on the new Brampton Transit Radio System:
LTR Trunked
Licensed to Mobile Business Company, Call Sign CZD217, Transmitter Site CN Tower Toronto.
Frequencies used:
937.0125.0375.0500.0750.1625.1750.1875.2000.2125.2250.2375.2500
938.5125.5375.5625.5750.5875.6125
939.1375.1625.1875.2125.5750.5875
It appears that each bus has a separate ID; the following ID's were noted:
1-01-171 1-01-162
1-01-126 1-01-111
1-01-169 1-01-192
1-01-178
Bus drivers cannot talk to each other; all communications go through dispatch. One of the dispatchers has a thick British accent, this should help you identify a Brampton conversation.
tonsoffun
Senior Moderator
Central Ontario
Re: Brampton Transit Frequencies
LTR Trunked
Frequencies used:
1-01-171 1-01-162
1-01-126 1-01-111
1-01-169 1-01-192
1-01-178
Now thats more like it!!!! I did not think those other frequecies that where posted where right!!
Good job Transitman
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Good work !
I wish my scanners tracked LTR, but I've put the freq's in anyways.
One thing though, only these freq's are licensed to this address in Brampton
Mobile Business Communications Ltd.
939.8250 100 COUNTY COURT BD ,BRAMPTON
939.8375
939.8625
939.8750
I'm thinking that only these would be required for B.T's needs, though I may be wrong.
Thanks for sharing the info.
docu
Brampton transit
Yes great job transit guy now all we need are all the ids because they need to be programed in order.Correct me if i'm wrong if there not in order it won't follow the conversation i think.
DaveH
Ottawa, Ont.
LTR Trunked
Frequencies used:
I notice there are 24 frequencies under that licence, which means that either some are not used, or there are more than one LTR system (limit 20 channels per system).
The Home Repeater order is important, except for PRO-92/2067 users. If I were there I'd be on the case...
Dave
poppys780bc
BRAMPTON TRANSIT
Could someone tell me how to program Bramptom Transits LTR radio system.I have a 796D. Before they changed (Jan 2005) I was able to get them fine but now am having difficulty. I can get them sometimes on 800 but it is very noisey. Someone said that they were on the 900 freq but I can not find them Please help
Thornhill20
Toronto, Ontario, Canada
I live in Toronto and I've got no problem hearing traffic on the MBC systems.
I wouldn't have a problem using a computer to run trunker or something to try and nail this system down...but my question is - is there a version of trunker or something that does LTR systems?
As well...there's been lots of talk here and other places about which system it is...the one in Brampton or the one on the CN Tower. I would be inclined to believe it's the one in Brampton...it seems really stupid to put BRAMPTON transit on a system in TORONTO when there's already a system in Brampton. Plus, I heard from a tech that Brampton Transit will be on a completly new system...ie...new for even MBC, which leads me to believe that it's the system listed in Brampton.
Maybe someone could clear this up?
-M
Eddie66
Bolton, Ontario
Brampton
My understanding is that this is a temporary fix and the Brampton has been piggy back onto MBC for now. The frequencies that I've got doesn't seem to work on my BC780. It doesn't want search for ID's properly. I was told that they were using the county court tower with 10 frequencies they are using.
DaveH
Ottawa, Ont.
Unless the LTR Home Repeater IDs for all channels are known and you program the 780 bank positions according to it, you won't be able to scan/search properly. The best you can do is sit on each channel in manual mode and watch the ID's go by.
It's not safe to assume that the HRs are in ascending order starting at 1. For a 5-channel system it is more likely 1-5-9-13-17. You could try that but no guarantee.
To track this system properly, SOMEONE (it doesn't matter who) needs to spend a bit of time to figure it out. There are some techniques depending on what equipment is available.
Dave
Eddie66
Bolton, Ontario
City of Brampton
I guess we need someone to sit at County court and figure this one out, I know I don't have the equipment but hope someone out there would take the time to figure this LTR lineup. I wait patiently for someone to share.
:cry:
