BRICS System
davidjacobs2012
Cheviot, OH
Does anyone know exactly what this means: "The Butler Regional Interoperbility Communications System (BRICS) will connect it's zone controller to the statewide MARCS-IP system. It is expected to become Zone 4 within the MARCS-IP network. Butler County will be a Tier 5 Partner and surrounding counties Clermont, Hamilton and Warren may tie in the Zone 4 controller. This change will take place in the coming weeks. Please keep a close watch on this system for the changes."
I just need someone to explain in simple words and terms. Thanks
radioscan
Radio Sensei
Southern Ohio
Yes, I wrote it. It means that BRICS as it's own system will be absorbed into the statewide MARCS-IP system. It will become a part of MARCS-IP as it's own Zone just like Lake and Jefferson counties in Northeastern Ohio are now. Butler County is keeping their own system controller and will link it into MARCS-IP. Eventually Clermont, and possibly Hamilton and Warren counties will tie into that controller so all the local counties in Southwestern Ohio will be a part of Zone 4 of MARCS-IP. Think of it like this. The system covers the entire state, but is split into regions, these regions fall under a "zone" within the system. Butler County should be fully integrated into MARCS-IP sometime in the next 30 days or so.
Here is a link to the wiki article explaining MARCS local partnerships
http://wiki.radioreference.com/index.php/Ohio_MARCS_IP:_Local_Partnerships
Sent from my Galaxy Note 10.1 using Tapatalk
davidjacobs2012
Cheviot, OH
So then we will see the Butler County channels on the MARCS-IP system and no longer on the current stand-alone system?
Sent from my VK810 4G using Tapatalk
mszabo2000
Rootstown, Oh
The Butler system will utilize the same frequencies as it does today. The connection to MARCS IP allows talkgroups to roam between the Butler and MARCS systems.
wa8pyr
Lead Database Admin
Ohio
Has anybody listened to Butler County on the new system yet? Does it sound good?
Shouldn't sound any different than it did before. Still a Motorola P25 system, same transmitters, same towers. They've just connected to MARCS-IP as a system controller instead of continuing to pay maintenance on a separate controller.
radioscan
Radio Sensei
Southern Ohio
I monitored it most of the day and it sounds fine, no difference at all.
Sent from my GT-N8013 using Tapatalk
heidorn39
I have the pro-106 and cannot get hardly anything from butler co dispatch. I live near liberty fairfield rd at Millikin. Is it my location? Anyone else have issues.
Matt: Still crappy reception
Almost like signal muted
davidjacobs2012
Cheviot, OH
Are you aware that butler county switched to the marcs-ip system? And if yes, are you monitoring the "butler co simulcast" site?
Sent from my Droid Maxx using Tapatalk
heidorn39
I believe so. There are 14 freqs listed on the site for butler county simulcast. I have those entered. I get hit and miss reception and not a lot of traffic. Wondering if there is a setting off in the pro106
davidjacobs2012
Cheviot, OH
I'm a Uniden guy, not a radio shack or GRE guy. The only other thing I suggest is make sure the firmware on the unit is up to date
heidorn39
What is a good uniden that u may recommend? I think the issue may be the radio itself.
davidjacobs2012
Cheviot, OH
Personally, I would get the new 436HP scanner. It decodes much better than the 396xt and 996xt models. However, those models would still pick up the Butler county system. The audio breaks up a lot due to the simulcast issues. I love my 436hp because it delivers great audio
