Bridgeton PD down?
nosoup4u
High Bridge, NJ
There's NO WAY you are picking up the NJICS system on a Pro-106 or 396T. Absolutely no way. I guarantee it. Post a link to a youtube video of it working. I'd love to see this...
The Delaware River Region talkgroups have been coming over as regular P25 (Not TDMA Phase 2). Any P25 scanner will receive those).
Septa3371CSX1
Drexel Hill, PA
I've monitored the NJICS with my Pro 106 and Pro 651. Of course it only works for Phase 1 talkgroups and not the Phase 2 ones.
New Jersey
I hate to tell you this, but I did pick up a partial transmition from Bridgeton police on the NJICS system with my pro-106 and I have video proof!!!!
I will up load it to my YouTube account
I think I'm too far because I'm only getting a 32% on signal strength.
https://youtu.be/1GzvubMNT8o
This system is crap....
jcardani
Orlando, FL
Bridgeton is using one of the Delaware Valley Inter-op talkgroups which are P25 Phase I. This is temporary.
I am sure when they finally get their own talk group, it would be Phase II like the other local PD on the system use (EX. Middle Twp. PD in CMC).
And again I feel like a broken record here..... It's not the system that is crap, it's the scanner! Scanners cannot handle the Linear Simulcast Modulation (LSM) properly.
The cheapest solution to the LSM issue is to create a bootable USB drive with Gnuradio and install OP25. Then buy a cheap Nooelec SDR and use OP25 to monitor. Unfortunately I could not get the Airspy to run in the environment. This method picks up LSM perfectly. See the following 2 threads:
http://forums.radioreference.com/so...e-op25-usb-boot-drive-persistent-storage.html
http://forums.radioreference.com/so...-virtualbox-project-run-op25-windows-7-a.html
The only other option is to use a real radio programmed RX only to monitor. The only 2 that do not require a system key for RX are the Relm Wireless or certain Harris models. With the Harris you have to be careful of the firmware version that's in the radio and RPM version that is used to program it. And be prepared to spend upwards of $1400 or more.
PM08203
Somers Point NJ
FYI: While in Atlantic City today I picked up TG 4191 off the Hammonton tower. Based on street names
I believe it was Bridgeton.
csmith00
NJ
Joe,
Thanks for pointing the USB link out. I hadn't considered using a SDR for this. I'm up and running but till trying to figure out all the settings. I'm mostly hearing Bridgeton on 4191 and NJT traffic on 3731. I left the modulation out of my trunk.tsv file. Seems like I hear more traffic that way. For example, things are silent if I use TDMA. But I need more listening and play time.
N2ICV
Gloucester County FM29in
Here come P25P2 for
CUMBERLAND, COUNTY OF
[APPLICANT IS A COUNTY GOVERNMENT. RADIOS WILL BE USED TO COORDINATE PERSONNEL AND ACTIVITIES.]
Control Point 1 - 637 BRIDGETON AVE, BRIDGETON NJ 856-455-8526
(link)
09/01/2016 New Application Received
1 - Bridgeton, NJ STATE POLICE CARLS CORNER, BRIDGETON (Cumberland) NJ [Structure: Lattice tower] (map)
[Antenna 1 - HTT: 59.4m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 9.5dBi, HAAT: 63.1m]
769.28125 FB2 Ant: 1 200p 200e Units: 1 8K10F1E 9K80D7W (P25 Phase II)
769.78125 FB2 Ant: 1 200p 200e Units: 1 8K10F1E 9K80D7W (P25 Phase II)
770.03125 FB2 Ant: 1 200p 200e Units: 1 8K10F1E 9K80D7W (P25 Phase II)
770.29375 FB2 Ant: 1 200p 200e Units: 1 8K10F1E 9K80D7W (P25 Phase II)
771.04375 FB2 Ant: 1 200p 200e Units: 1 8K10F1E 9K80D7W (P25 Phase II)
771.54375 FB2 Ant: 1 200p 200e Units: 1 8K10F1E 9K80D7W (P25 Phase II)
772.03125 FB2 Ant: 1 200p 200e Units: 1 8K10F1E 9K80D7W (P25 Phase II)
772.30625 FB2 Ant: 1 200p 200e Units: 1 8K10F1E 9K80D7W (P25 Phase II)
772.85625 FB2 Ant: 1 200p 200e Units: 1 8K10F1E 9K80D7W (P25 Phase II)
773.19375 FB2 Ant: 1 200p 200e Units: 1 8K10F1E 9K80D7W (P25 Phase II)
773.68125 FB2 Ant: 1 200p 200e Units: 1 8K10F1E 9K80D7W (P25 Phase II)
773.95625 FB2 Ant: 1 200p 200e Units: 1 8K10F1E 9K80D7W (P25 Phase II)
774.21875 FB2 Ant: 1 200p 200e Units: 1 8K10F1E 9K80D7W (P25 Phase II)
2 - Cumberland Fire Co, 5272 Route 49, Millville (Cumberland) NJ [Structure: Lattice tower] (map)
[Antenna 1 - HTT: 53.0m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 9.5dBi, HAAT: 53.4m]
3 - FORTESCUE, 317 NEW JERSEY AVE, FORTESCUE (CUMBERLAND) NJ [Structure: Lattice tower] (map)
[Antenna 1 - HTT: 54.9m, Polarization: Vertical, Beamwidth: 180.0°, Gain: 7.5dBi, Azimuth: 10.0°, HAAT: 53.7m]
4 - Millville, 122 East Main Street, Millville (Cumberland) NJ [Structure: Building with antenna on top] (map)
[Antenna 1 - HTT: 36.9m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 9.5dBi, HAAT: 24.2m]
5 - PORT NORRIS, MAURICETOWN HALEYVILLE ROAD, COMMERCIAL TWP (CUMBERLAND) NJ [Structure: Lattice tower] (map)
[Antenna 1 - HTT: 46.0m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 9.5dBi, HAAT: 46.0m]
6 - VINELAND, 1676 E LANDIS AVE, VINELAND (CUMBERLAND) NJ [Structure: Tank] (map)
[Antenna 1 - HTT: 47.2m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 9.5dBi, HAAT: 45.3m]
7 - (CUMBERLAND) NJ Countywide
799.28125 MO Ant: 1 30p 30e Units: 4100 8K10F1E 8K10F1W (P25 Phase II)
799.78125 MO Ant: 1 30p 30e Units: 4100 8K10F1E 8K10F1W (P25 Phase II)
800.03125 MO Ant: 1 30p 30e Units: 4100 8K10F1E 8K10F1W (P25 Phase II)
800.29375 MO Ant: 1 30p 30e Units: 4100 8K10F1E 8K10F1W (P25 Phase II)
801.04375 MO Ant: 1 30p 30e Units: 4100 8K10F1E 8K10F1W (P25 Phase II)
801.54375 MO Ant: 1 30p 30e Units: 4100 8K10F1E 8K10F1W (P25 Phase II)
802.03125 MO Ant: 1 30p 30e Units: 4100 8K10F1E 8K10F1W (P25 Phase II)
802.30625 MO Ant: 1 30p 30e Units: 4100 8K10F1E 8K10F1W (P25 Phase II)
802.85625 MO Ant: 1 30p 30e Units: 4100 8K10F1E 8K10F1W (P25 Phase II)
803.19375 MO Ant: 1 30p 30e Units: 4100 8K10F1E 8K10F1W (P25 Phase II)
803.68125 MO Ant: 1 30p 30e Units: 4100 8K10F1E 8K10F1W (P25 Phase II)
803.95625 MO Ant: 1 30p 30e Units: 4100 8K10F1E 8K10F1W (P25 Phase II)
804.21875 MO Ant: 1 30p 30e Units: 4100 8K10F1E 8K10F1W (P25 Phase II)
8 - (CUMBERLAND) NJ Land mobile control station meeting 20 rule
799.28125 FX1 Ant: 1 30p 30e Units: 10 8K10F1E 8K10F1W (P25 Phase II)
799.78125 FX1 Ant: 1 30p 30e Units: 10 8K10F1E 8K10F1W (P25 Phase II)
800.03125 FX1 Ant: 1 30p 30e Units: 10 8K10F1E 8K10F1W (P25 Phase II)
800.29375 FX1 Ant: 1 30p 30e Units: 10 8K10F1E 8K10F1W (P25 Phase II)
801.04375 FX1 Ant: 1 30p 30e Units: 10 8K10F1E 8K10F1W (P25 Phase II)
801.54375 FX1 Ant: 1 30p 30e Units: 10 8K10F1E 8K10F1W (P25 Phase II)
802.03125 FX1 Ant: 1 30p 30e Units: 10 8K10F1E 8K10F1W (P25 Phase II)
802.30625 FX1 Ant: 1 30p 30e Units: 10 8K10F1E 8K10F1W (P25 Phase II)
802.85625 FX1 Ant: 1 30p 30e Units: 10 8K10F1E 8K10F1W (P25 Phase II)
803.19375 FX1 Ant: 1 30p 30e Units: 10 8K10F1E 8K10F1W (P25 Phase II)
803.68125 FX1 Ant: 1 30p 30e Units: 10 8K10F1E 8K10F1W (P25 Phase II)
803.95625 FX1 Ant: 1 30p 30e Units: 10 8K10F1E 8K10F1W (P25 Phase II)
804.21875 FX1 Ant: 1 30p 30e Units: 10 8K10F1E 8K10F1W (P25 Phase II)
csmith00
NJ
Here come P25P2 for
(link)
Yes, a separate thread about it started a few days ago.
New Jersey
Where and How can I get a Harris XG-75P RX only Radio? I understand it might cost $1400.00 maybe more, i would just like to know where to purchase one... Thank you.....
New Jersey
********UPDATE*******
bridgeton PD is now on NJICS system talk group 4531 and 4533.
They are P25-Phase2 TDMA
Just heard them on my BCD436HP, but didn't hear them on my Pro106 or my Pro 97....
W2SJW
Senior Member
Northwest NJ
Considering the Pro-106 won't do Phase-II & the 97 won't do digital at all, I'm not sure what the point of this post is. Those talkgroups have also been in the DB for over a week as well...
W2SJW
Senior Member
Northwest NJ
Well, they're encrypted, so no one is hearing them...
Sent from may Galaxy S6 via Tapatalk 6
