Broadcast screen?
KO4IPV
Working with the SDS100/ Should my broadcast screen be off ? Or on
KO4IPV
Ok since I don’t use close call ! it probably doesn’t make a difference if it’s on or off correct? It’s in the off position now with no close call active.
IndyScan
Always Connected...
Fishers, IN
I run mine on just to help ignore interference from TV/Radio/Pager sites. Probably not going to have an impact if you're not using CloseCall (which is pretty cool when it triggers).
KO4IPV
Yes close call is good but since everything is DE in my area it doesn’t work so well , I listen to 40 mile away county’s , unless I go mobile then the gps works great. Thanks for the help!!!
