My local public services are moving to P25 Phase II next summer, and I got a nice bonus at work so I am looking for a scanner to replace my 996XT which I use to broadcast our local services here to Broadcastify.
I have been looking for a new P25 Phase II scanner, and my choices are between the HomePatrol 2 and the SDS200.
While the HomePatrol 2is cheaper looking around it feels like it has been abandoned with updates. I have a HomePatrol 1 and while it works great it seems like it is no longer supported with updates. But the Homepatrol 2 has a line output jack, I like having a line output so I can still listen to the scanner while I am sending audio to my Broadcastify encoder.
I notice the SDS200 does not have a line output (or record output) but looking around it appears you can send audio out from the SDS200 over ethernet, I am guessing I will still need an encoder PC to send it to Broadcastify. (It would be cool if I could just have it stream from the scanner.)
So using the ethernet port what do I need to broadcast to broadcasting?
Am I better off buying the HomePatrol 2 or a SDS 200? Which would you get?
Thanks!
Thanks!
