Broadcastify Streaming Question
Brownjv14
Owner of Halifax County Public Safety
Halifax, NS
Hi all, I am currently running a scanner feed on Broadcastify and had a couple people report that there is a pulsing beep on the stream when there is no one talking on the scanner, just curious too see if anyone out there would be able to assist with this problem... I have posted the feed link below if anyone would like to have a listen.
https://www.broadcastify.com/listen/feed/35056
Deziel0495
PE/NB Database Guy
PEI
I listen to your feed regularly and haven't heard that. Could be a ground loop, which is easily solved by getting a ground loop isolator. Can pick one up on Amazon for a few dollars.
n9mxq
Belvidere IL
The only time I've heard the beeps on my feed, is when the connection is temporarily lost. As soon as the system connects back, the beeps go away. I believe it's the Broadcastify app that does it to notify the listener that the connection is trying to fix itself.
