So I've got the NXDN upgrade, and I've been monitoring a repeater that the local hospital here uses. First I tried programming the frequency in a conventional system with the audio type set to digital only, but it seemed like I was missing bits of the conversations. So I fired up DSD+ next to the scanner, and indeed the scanner seemed to be missing around 50% of the transmissions.
So I tried programming the frequency as a NXDN one frequency trunk. Now here's where it gets interesting. If it's the only enabled system in the scanner, it decodes 100% perfectly, audio is good and clear, it shows a talkgroup ID of 0 which I understand is normal. If I enable another trunked system, say the local P25 public safety system, it completely stops decoding the NXDN system. When the NXDN repeater is active (verified with DSD+) the scanner will actually stop on it, it'll show the 5/5 signal bars, but there will be no audio and no talkgroup shown. As soon as I turn off the P25 system, it'll start decoding audio on the NXDN system.
As a test, I've left it on overnight, with the scanner connected to Proscan for the history logging, the NXDN system enabled, along with the P25 system enabled but with all talkgroups locked out so it won't actually stop on anything. DSD+ running as well all night. The DSD+ log will be full of calls from the NXDN repeater, but the history log in Proscan will be completely empty. As soon as I turn the P25 system off, and it starts decoding the NXDN system again, the Proscan log begins to fill.
Sounds like a bug perhaps?
