FM and nxdn conventional scanning
astropil00
I'm hoping to build a small system for monitoring a mix of conventional analog, nxdn, and potentially some DMR from spare parts I have.
From what I've understood what will work with linux (please let me know if this is not correct):
op25 - can do conventional fm, nxdn, etc but only using the multi_rx and would require enough SDR dongles to cover the required bandwidth
dsd-fme - can do conventional nxdn and dmr using a scanlist but not fm
sdrtrunk - can do conventional fm and dmr but not nxdn and would require enough SDR dongles to cover the required bandwidth
rtl_airband - can do conventional fm with a scanlist but not nxdn or dmr
Wondering if anyone might know of a software on the linux side that can decode all of these in one go using a scan list (ideally something that could hop through a frequency list like DSD+ on Windows)?
I think I remember seeing a post somewhere about someone trying to feed the output of rtl_airband to dsd-fme but don't recall if it was possible for the frequencies that are not just fm.
