Airdorn
I looked at the gamma match style, but it looked harder to construct than what I chose.
It was very easy to make the driven element -- I cut a piece of the steel rod to the correct length, drilled some tiny holes at each end, then inserted a couple of pieces of very thin welding rod and soldered them.
Then I carefully bent each rod down and fed it into a couple of grommets and into the body of the antenna where I soldered each to the feedline as shown in the picture I drew in a previous response.
It only took maybe 30 minutes with a drill press and 75 watt soldering iron.
