jjlongworth
I've received some great feedback on my post for building a Monitenna. I've also received a couple of requests for similar plans for a Scantenna.
I don't own one. So, the next best thing is to build my own (I refuse to pay eBay prices). I have scoured the internet and download a ton of photos of the original along with the AntennaCraft documentaiton. I've got enough images that I was able to bring the images into Adobe Illustrator and draw the important parts to see how it is assembled. What's really interesting is how many I have found, in photos, that are assembled incorrectly! I even found a YouTube video where a guy cut one up to make a TV antenna out of it!
I think I've got the proportions pretty close. I'm able to scale it to get rough dimensions based on some assumptions. However, it is almost impossible to get precise dimensions. I've created the attached drawing which identifies what, I think, are the critical dimensions. Each one is identified with a corresponding number and there is a table with matching numbers. If you have access to an antenna and can provide some, or all, of the dimensions, I will get to work on writing a similar document. I'll take the dimensions however it's easiest for you to provide them: you can scan the form and post it, email it or just post the corresponding number and dimension. The bulk of this antenna will be based on the Monitenna since the center portion is very similar.
BTW - For those who are interested, I am working on revision D of the Monitenna document. I've found some grammatical things and I will be making some suggestions for sealing the elements and insulator.
