Burlington county system
joey123
nj
Any suggestions on scanner filter setting for the sds 100 I’m located near the moorestown mall nj it skipping transmission and audio is bad
Whiskey3JMC
Don't spoonfeed the OP
Simulcastylvania, TE
Personally when I'm able to pick up the system from the Montco, PA side across the river from Roxborough section of Philly, I'm able to get a reliable decode with filter on my SDS100 set to "off" with 3 to 4 bars and RSSI about -101 INDOORS at that!
policefreak
Berlin, NJ
Set filter to Wide Invert. Then set Attenuator to ON. Thats how I hear it when I pass through the area daily. And my SDS 100 almost never drops a transmission that way. I believe you must be near the antenna farm which is causing interference with the attenuator off.
Whiskey, that's impressive!
