orbital
I would be very thankful if someone could help with this issue.
Here is what's happen.....
I decided that I wanted to use the Virtual Scanner in my ARC246T software
well it worked fine until I tried to enable Logging.
Since I do not run myself as Administrator, I had to log into the Admin account
to check the box to enable logging. While in the Admin account I check to see
if everything was working correctly and it was. It was creating the csv log file
just like it should.
Well, I logged back into my Limited User account and the software works fine
but every time I try to close the Vitural Scanner it gives me this Error Box
Runtime error '75'
Path/File Access Error
Ok, I know this is some form of permission error. Because if I give my Limited
User account ADMIN rights the error stops...... now how do I make it stop.
Now even when the Log box isn't checked this error happen. The Virtual Scanner
works, it's just when I close it, the error pops up..... How do I make it stop.
I looked at the csv file permissions and both my Admin and User have FULL permissions on that file....
Plus my Limited User Account " owns '" that file.
So what doesn't it have access to?
Stumped......................
Thanks.
Runtime error '75'
Thanks.
