Buy an amateur radio now or wait?
Aviation_Scanner
WSEY205
Houston, Texas
Should I wait until I get my license & join a club to get a HAM radio?
I currently own a radiooddity GM-30 Plus GMRS HT, which I like a lot and is easy to use.
I was thinking about getting the same brand in a HAM radio,
AK9R
Super Moderator
Central Indiana
I don't think there is a "correct" answer to this one.
Many new hams buy a radio before getting their license and becoming active. This gives them an opportunity to monitor and get a feel for amateur radio.
But, it might be wise to wait until after so you can get a sense of what you might be interested in once you have that license.
Aviation_Scanner
WSEY205
Houston, Texas
But, it might be wise to wait until after so you can get a sense of what you might be interested in once you have that license..
I already know I would like a handheld, since I do not have the room at my mom's house for a base setup and nor will the HOA allow for tall antennas. Mobile radios are absolutely a no go for me either, since I do not want to ruin the interior/exterior of my car.
My first goal is to explore communicating with others on the bands permitted by a technician license along with maximizing my knowledge & experience at the technician level before advancing to the general.
My long term goal, since I am an ex-volunteer firefighter, I would like to get into emergency communications.
hill
Middle River, MD
A handheld radio is going to limit you a lot, as your first radio and you will get frustrated quickly. Many repeaters are hard to access with a small antenna on the HT and only having 5 watts.
You can have a radio inside the home without much showing outside or nothing with antennas indoors like the attic. VHF/UHF antennas aren't not too big and easy to fit inside. An antenna in the attic with a mobile radio will serve you much better than just have having an HT.
Many mobile radios have remote displays and you can mount the main radio under the seat. You can get by with a small 19" antenna and this will allow you to access all the local repeaters with ease. Guess it doesn't matter to me with two radios, plus a scanner in Elantra with three antennas on the trunk.
In time as you grow in your ham radio journey you will have acquired many radio and maybe you think different of having radios in vehicles.
prcguy
If talking on amateur radio is a goal then don't buy a radio until you have a license. For one thing it will be an incentive to get your license, then you pick out a radio. Buy the radio now and you have your fix and less incentive to get the license.
I've been there and done that many times over before getting my license.
Aviation_Scanner
WSEY205
Houston, Texas
Actually, I already know that part from having a GMRS handheld, although I am able to hit a GMRS repeater about 10-15 miles away with the stock antenna.
I just don't have a room I can dedicate to having a base station, although I could just set it up in a room along with the indoor antenna & take it down when I am done.
The other factor is my financial situation. After looking into prices of base/mobile radios, I find that I cannot afford them whatsoever.
But I have learned if there is a will, there is a way.
Good point and one that I will follow.
hill
Middle River, MD
Another great route ham radio gear is going the used route.
If there is radio club in your area many hams have gear that wish to get rid of to purchase the latest and greatest. Hams mainly keep there gear in great shape and good way get into hobby at a reduced cost.
I have a lot ham radios and scanners purchased used and really increased my collection of both recently with our radio club unloading gear from a silent key. Much of this stuff would have never purchased at new prices, but will get me into some more modes like D-Star.
I'd wait a bit.
Your GM-30 can be programmed to receive frequencies outside the GMRS band, so as you learn, you can try programming some local amateur radio frequencies into the radio you already own. That'll let you listen in and start learning some of the procedures and habits of local amateurs.
I often see new hams blowing their budget on their first radio, without really having a good idea of what they need. I know your budget is tight so don't rush into a purchase just yet. As you learn the subject material and listen in on local hams, you'll get a much better idea of what you need and what you want. You may find that the local 70cm band is dead, or that most use a digital mode. You may find that 2 meters is where the local action is at, and you can choose a single band radio to fit your needs. You can also talk to the local hams at the club, and you may find, as suggested above, that there are used radios for sale.
Don't be in a rush to spend money. You've gone back and forth on whether amateur radio is right for you a few times. If budget is a concern, wait, there's no rush. With Amazon, you can find an inexpensive radio and have it delivered quickly once you have a better idea of what you need.
Sound advice.
I waited until I had the new license in my hand.
Then I went out and blew a bunch of money on the "best" hand held radio. At the time it was a modern marvel of dual band analog goodness. One of the early dual band radios to hit the market.
Quickly found a few things that were specific to my location:
1. 70 centimeter band was pretty dead, rarely got to use it. The fancy dual band radio spent 99% of the time on VHF.
2. A hand held radio didn't work well unless I was standing outside on the side of the house facing the hills.
So, half the radio didn't get used enough to really justify it.
I still had to go outside to talk on the repeater.
About a year later, my second ham radio purchase was a single band 2 meter mobile installed in my truck with a good external antenna. Commute time gave me much more opportunities to talk on the radio, and with that setup it didn't really matter where I was.
There's zero reason to "destroy" your car installing a radio and a good antenna. Careful planning can make a decent install fairly easy and will give you much better results.
Or, at least use a battery adapter that lets you run the radio off the 12 volt socket in your car and a magnetic mount external antenna.
Aviation_Scanner
WSEY205
Houston, Texas
Little does he know that as soon as he gets his license and his address shows up on the 'net, I'm going to do a late night drive-by and drill a hole in the top of his car. That's the way I roll… Have hole saw, will travel. Wire mmckenna, San Francisco.
And little do you know, I will have a killer guard cat on duty :ROFLMAO:
KF6DGN
Milton Florida
STOP! Before spending any $ I recommend you get on the "air" using your phone or tablet. You can talk to the World for zero $.
Get on DroidStar see http://QRM1717.com
DroidStar download wVocoder.pdf
Another great app is EchoLink. Introducing EchoLink
Lastly I recommend the Peanut app, peanut
Some of my fellow hams may frown upon my advice. But you can see what modes you like before spending hard earned dollars on a radio.
Now if you really must get on the local repeater look at the easy to use a Yaseu FT-70DR under $200. You can use a local repeater or a hotspot to talk around the World.
YouTube has a lot of great videos for ham radio. It was like a virtual Elmer for me.
7 3
David
P.S. before you do any of the above go to Home and register your call sign.
