Buying a digital scanner
timhir25
Willoughby, OH
I am also looking to buy a new scanner. I have a GRE500, Two PSR800's, and a WS1098. The WS1098 I have on 24/7.
I have been thinking SDS200.
Here are some of my concerns though before I shell out almost $900.
1) The TRX2 comes with the DMR and the NXDN already installed. Where as the SDS200 I have to pay another $75 for each upgrade.
2) What is this I have been reading about the cold solder joint and the humming.
I mean I don't want to here about any problems with the 200 when you are spending that kind of money.
3) Finally is the SDS200 that much better then the TRX2
I live in Willoughby Ohio and my scanners set up to listen to Lake County.
Any input will be greatly appreciated.
Happy Holidays everyone, and STAY SAFE
Tim
Whiskey3JMC
Formerly known as the Delco Scan Man
Philly burbs 🇺🇸
I recently purchased the SDS200 and haven't had a single problem with it.
If you live in a Simulcast-prone area, it's the only solution that works.
Based on Tim's location, looks like Ohio MARCS-IP would be the primary system of interest for LE, Fire, EMS, etc. System is Phase-I so it doesn't appear simulcast distortion would be an issue on it since none of the sites are reported as simulcast. TRX-2 should work just fine
timhir25
Willoughby, OH
My WS1098 seems to work just fine. Also I am use to the EZ Scan software. That's why I was thinking TRX2 but I read about how great the SDS200 is.
buddrousa
Tim
If you buy direct from Uniden at my.uniden.com
NXDN = $50
DMR = $50
PROVOICE = $50
BigJimbo
Dayton, Ohio
If Lake County is simulcast, you will be much happier with an SDS. If there's any chance you would listen while mobile, or just like to take the scanner anywhere in the house, you may want to consider the SDS100. The 200 has a larger speaker, and does produce a bit nicer sound, but they both perform the same.
I have both. I've not had any issues with the 200. The battery clip that holds the battery cover to the radio broke on my 100. I ordered replacement clips from a member here on RR and replaced the clip myself. Easy to replace and my radio was back to normal in a week, as opposed to sending it to Uniden for repair.
Also- If you're going to upgrade (I've done the DMR and NXDN on both) go direct thru uniden, much cheaper.
fredva
Virginia/West Virginia
MARCS is a mixture of multi-site and simulcast. The System Type being Phase 1 or Phase 2 is not an indicator of whether simulcast is being used but rather whether TDMA or FDMA digital modes are used.
iMONITOR
Silent Key
S.E. Michigan
Buy from a reputable Uniden dealer like Scanner Master where you can return a radio for a refund or replacement if you get a bad one. It appears new SDS scanners shipping in recent months are without problems.
Scanner Master
fordcobra04
Montgomery County, Ohio
Going to throw the Unication G4/G5 in the ring. Superior performance on simulcast systems over any consumer grade scanner on the market. A little more pricy, but worth it for the performance.
jonwienke
More Info Coming Soon!
VA
The Unications are a good option if you're only trying to monitor a single system. But they're not really suitable for general scanning.
