Hi folks, I could use some advice.
I'm intending to purchase 2 XPR3500e radios (UHF) via eBay. Before I do, I have a few questions that one of you might be able to help with. Note that I already have a Motorola Solutions account, have the entitlement for CPS, and have the programming software. I also bought a programming cable and I intend to use this on the FRS frequencies in the US (to which I also have a GMRS license from the FCC if it is needed).
- Are there any questions I should ask the seller ahead of time? I saw vague references in the forums to password locks on radios where they can't be reprogrammed.
- I'd like to use the encryption options, specifically the RC4/enhanced privacy. Will I need to buy an entitlement? It's unclear in the Motorola docs. If yes, are there any restrictions in buying an entitlement for a used radio (that might have had a prior entitlement for a different customer)?
- I also saw some threads on wideband entitlements. I don't expect that I will need this for my use case as described above, but just want to confirm.
- Any other advice you have would be appreciated.
