Buzzing tone. Looking for some help. Beginner
grinner
Mike
Marysville, 98270
Snohomish County
I got hurt and looked for a hobby...I have a new RS pro-163 and a subscription to RR. Total beginner. I've got trial versions of Win97 and ARC300. What's that insane buzzing sound?
Can you show me how to program: http://www.wa7dem.org/
DickH
Mike
Marysville, 98270
Snohomish County
That buzzing sound is the data being sent over the control channel. If you are hearing that, the scanner is not "trunking".
You need to understand how trunking works. The following may help:
The object of trunking is to allow many users to share a relatively few frequencies.
A trunking system is controlled by a computer. Information (data) is exchanged between the radios and the computer on a control channel, sometimes called a data channel. It sounds like a strong buzz.
A large Motorola system can have up to 28 freqs., 4 of which may be used as control channels. The control channel may be changed once a day or as often as the programmer decides. Some scanners need only the control channels to track the entire system. In that case just enter only the control channels.
After the frequencies are entered, the banks become scan lists or sub-banks that hold the Talk Groups or IDs.
Each group of users (Fire, Police, etc.) is assigned TALK GROUPS. In a Motorola Type II system, the most common type, TGs are usually in 32 number steps starting with 16 and going up to 65536; 16, 48, 80 --- 4656, 4688, 4720 --- 28944, 28976, etc. System radios can have more than 100 TGs programmed into them.
When a user pushes the talk button on his radio, data is sent to the computer. The computer chooses an unused freq. and sends that data to all the radios using the TG of the originating unit. This all happens in a fraction of a second and it happens EVERY time a radio is used.
EXAMPLE:
Fire Dispatch calling Engine 4 (TG 4528 on 856.7125)
Engine 4 answering Dispatch (TG 4528 on 867.2625)
Respond to 73 Elm Street (TG 4528 on 855.9625)
Engine 4 responding (TG 4528 on 858.4375)
If you have entered TG 4528 into your scanner, it will decode the control channel data and change your scanner freqs. to follow the conversation on TG 4528.
Some scanners have 2 modes, OPEN and CLOSED or SEARCH and SCAN.
OPEN or SEARCH receives all TGs using the system.
CLOSED or SCAN receives only the TGs YOU have put into the scan lists.
This should get you started, but you should read the manual carefully. You may need to read it several times.
grinner
thx Dick
As you probably suspect, the manual wasn't as much help as I'd like. Thanks for the info.
-Mike
grinner
I liked this document
Well written and helpful. Thanks for helping out a new guy....thinking about putting an antennae on the roof!
texasemt13
CenTex DBA
Hunter, TX
. . . thinking about putting an antennae on the roof!
Oh that's dangerous talk now son... you might just get hooked on this hobby if you're mentioning that in your 3rd post.
Welcome to RR. More info than you'll ever need.
grinner
Thanks everyone
Nice to see folks looking out for one another.
I'm enjoying my new hobby...thanks for the help.
-Mike
