RH96: Cable Pinout
nycspirit
Marshburg, PA
Does anyone know the matching pin configurations on either side of the RH-96 data cable? I bought a “new” RH-96 on EBay only to discover it was missing the data cable and the seller was at a loss to provide it.
I found on EBay a MINI4P to USB Type A cable and cut the USB connector off so I can attach a 3.5 mm 3 pole plug, but I need to know which wires to connect to the top, center, and bottom rings of the plug.
Any help anyone can provide is sincerely appreciated.
John
scosgt
I did build a serial cable for that RH. I don't recall the pinout, but I did find all the info online. You have to search for it but it is there.
You can also just buy the cable. I think they are around $10
sfletcher268
Woodland, CA
scosgt -- I've not been able to find a replacement cable. Do you know where they can be purchased?
kruser
Well Known Member
W St Louis Cnty, MO
The cable for the RH-96 is a standard serial port level and no USB is involved. Many mistake the odd connector on the front panel of the 996T and XT models as well as the side connectors on the portable models as Mini USB connectors. They are not, they are a slightly diferent connector that does resemble a mini-usb connector until you look at it a little closer. I forget what the connector is officially called but there was a very old post when someone had found some short USB cables that had the standard USB A end on the computer end and this odd connector on the other end that Uniden used. I seem to recall it was called a Hi_rose connector but I think that may have actually been a Chinese manufacturer of cables and connectors and not really the connector name. Anyway, the old eBay link for the 4 inch adapter cables was a good source of the connector. One just needed to remove the computer USB A end and splice the remaining connector to whatever they needed to attach the front Uniden ports too. A DB-9 for programming and firmware updates or a standard 1/8th inch (3.5mm) stereo connector if making a cable for the RH-96.
I forget the actual RS-232 pinout for the cable and connector but it was very simple to build your own. Use a meter and determine the ground or common wire and that will be the sleeve on your 3.5mm plug. The only other signals were the TX and RX data signals. One of course went to the Tip and the other to the Ring on your stereo plug. If your baud rates match on the scanner and your RH-96, it should work. If not, simply reverse the RX and TX wires at the stereo plug or whichever end is easier and you should be good to go. Being RS-232 levels, reversed wiring will not cause any damage to either device. If the RH96 still does not work, double check that the baud rates match on both the scanner for that port and the RH96. Also double check the wiring again and make sure the common or ground wire is on the sleeve of the stereo connector. The corresponding pins if working on the DB-9 end are Pin 5 for the common or ground wire and pins 2 and 3 for the TX and RX data signals.
On the 996T and XT models, the rear DB-9 connector will also work with the RH-96 using a properly built cable and correct baud rate settings in the radio.
The RH-96 will also work with the rear DB-9 connector on the 536HP model as well as the odd serial connector on the side of the 436HP model. You just select the correct baud rate on the x36HP models from the GPS setup menu which is found under the Set Your Location/Set Up GPS/Set Serial Port menu and choosing the matching baud rate for the RH96. I forget but you may need a Null modem adapter and possibly a gender changer if using the rear DB-9 port on the base models and are also using some type of pre-built cable. If rolling your own cable for using the DB-9 port, you would just wire it correctly so you do not need a gender changer or null modem adapter.
The SDS100 no longer has the odd looking serial port connector (or any standard serial port for that matter) so the RH-96 cannot be used with this model. Even if the SDS100 did have a serial port connector, the RH96 would probably not work very well with it due to all the screen info the SDS100 can output over the serial line compared with the much smaller command set output by the older models. If an SDS100 did have a serial port, an RH96 may display some info but it would probably be mostly unreadable gibberish. For an example, try hooking an SDS100 up to ProScan and set the Scanner Type in ProScan to an x96 or an x36HP model and see how the virtual display screen looks! That's a fair example of how a RH96 would display an SDS100 if you could hook it up to a RH96. The older models from the 15 up to the 536HP can work with the RH96 as long as the RH96 has the latest firmware applied that allowed it to work with the newer XT models when they were released.
fxdscon
¯\_(ツ)_/¯
The cable for the RH-96 is a standard serial port level and no USB is involved. Many mistake the odd connector on the front panel of the 996T and XT models as well as the side connectors on the portable models as Mini USB connectors. They are not, they are a slightly diferent connector that does resemble a mini-usb connector until you look at it a little closer. I forget what the connector is officially called but there was a very old post when someone had found some short USB cables that had the standard USB A end on the computer end and this odd connector on the other end that Uniden used. I seem to recall it was called a Hi_rose connector but I think that may have actually been a Chinese manufacturer of cables and connectors and not really the connector name. .
This is the connector specs:
https://www.mouser.com/ds/2/185/MQ172_catalog-939657.pdf
scosgt
Hold on!
I did build a serial connector which works with the 996T, but could not get it to work with a 996P2. Is there a trick to that? I have two of the RH units, one has the updated firmware, one is original. Not certain which one I tried with the 996P2. Now I may have to go back and try again.
eaf1956
Evansville, IN
Uniden updated the firmware on the RH 96 for the 996XT but they never did for the 996P2 so it won't work on the P2
scosgt
That's what I thought so how can it work on the 536?
scottyhetzel
Palm Springs Area / OrCo
John
Hi it’s called : Tip, ring and sleeve btw.
On the rs-232 side it’s pins 2,3 and 5. 5 being ground...
kruser
Well Known Member
W St Louis Cnty, MO
If you look a couple of posts UP he states it does
I did say that didn't I!
It's been quite a while since I've messed with a RH96 so I'll need to dig one out and see if it does work with the 536. I thought it did though but I could very easily be mistaken. Now my curiosity has got the best of me so I'll report back if it does or does not work with the 4 and 536HP models.
kruser
Well Known Member
W St Louis Cnty, MO
I'm glad someone mentioned this as I was wrong and these old RH96 units do NOT work with the 4 or 536HP models like I'd original said they would. Sorry for the misleading info. I guess that's a sign of too many toys and experiments over the years and I can't remember whet worked and what didn't work! I cannot edit my original post to remove my mistakes so hopefully this will be seen before people dig out there old RH96's and try to make it work with a 4 or 536HP and apparently the 996P2 series.
Thanks for catching this eaf1956
I could not believe all the custom cables I'd made up over the time frame I'd used the remote heads with my T and XT models. The original boxes were stuffed full of custom cables I'd made to extend them from a bedroom into a living room many moons ago. It seems like just a couple years ago in my mind.
Sorry again for the bad info I gave earlier.
