Calgary
willwilliams
Coalhurst
is anyone using the BC396T for the city, if so im looking for some help on setting up one. you can pm or email me direct. thanks in advance
BC_Scan
Vancouver BC
You would likely receive a quicker response if you post your question's here ?
What information are you looking for ?
Edmonton, AB
Hi, Will. Good to see you posting here.
I believe there are a few people using that radio on the Calgary system. Someone will probably speak up.
Jeff
willwilliams
Coalhurst
i wa looking to find someone in calgary i could compare m programming with. i guess there are alot of missed comms from this but no problem with a 785d. im thinking i messed it up.
HDMechanic
Calgary Alberta
The best way to get the programing your scanner to work in calgary is to down load Freescan or ARC396 program and down load the info from Radioreference. Its worth every dollar you spend to be a premium subscriber to down load into the above programs. I use the 396XT and 996XT and have had the 396T and down loaded from Radioreference and my scanners dont miss any coms. Hope this helps you out.
