460.325 is 107.2 PL. Did you check the database? If not, Click Database, and select Kentucky and the county you need.
460.325 is listed, and with a 107.2 tone. The other Sheriff's frequencies might use the same PL, as it's sometimes the case with one agency using several frequencies.
Does your scanner have a PL search? You might have to get em' the hard and dirty way by doing a little digging. If you find them, subit the information to the database to help out the next guy.
