XPR Can A Motorola XPR7550 Conventionally Monitor Capacity Plus Talkgroups?
JASII
Memory Capacity
As posted above, if Capacity Plus talkgroups were programed into a Motorola XPR7550 as conventional DMR channels and then scanned, would voice traffic be heard when scanning or would it just hang up on the Home/Rest Channel?
16b
Central Ohio
I have done that and it seemed to work, but keep in mind you will need to scan two channels (one for each slot) per frequency, which can eat up a 16-channel scan list pretty fast.
JASII
Memory Capacity
You can monitor Capacity Plus as a normal trunking system and having it set for RX only. No conventional channels needed
I have:
The RF Frequencies
The Color Code
The TGIDs
Is there anything else will need to program that in as Capacity Plus receive only?
K2NEC
5F6
Yes. You need to program it exactly as a Cap + subscriber.
This includes the channels in channel pool and order does matter when putting them in the voice list.
Also make sure your RID is less than 65535
