Can not pick up nothing
falcons2
Kearney nebraska
Hi, I got the Whistler 1065, I downloaded the winn 500 and upgraded RR. Downloaded all the programs I wanted and the radio seems to be programed. But the only thing I pick up is the school buses. I am in North Dakota in Mckenzie county. It says there are no trunked systems, only conventional. Any help would be greatly appreciated..Thanks Linda
bharvey2
Linda,
A few things come to mind: from what I can see, there aren't a log of radio systems in your area so I don't suspect you have a lot of channels programmed into your scanner. Are you certain that the frequencies that you have programmed into the channels aren't locked out? Though I don't have your model of scanner, I've had some that will lock out channels. They're programmed in to the scanner but the scanner ignores them during scanning. If you manually scroll through the channels, do you see the word "lockout or L/O"?
Another thought (I'm assuming your area to be a rural one) is that you may not be close enough to pick up radio traffic. Maybe a trip to downtown may net you better results. (It usually legal to go mobile with a scanner but it wouldn't hurt to check your state and local laws) If all is good to go, just be discreet, as some people get "weirded out" about such activities. If going mobile with your scanner is too dificult, an outdoor antenna may be of benefit.
Lastly, from what I see you're correct about there not being any trunked systems. This should make programming a bit easier. One last thing to try: Instead of scanning, manually park your scanner on one frequency, say sheriff or fire dispatch, for a few hours and see if you get any traffic.
falcons2
Kearney nebraska
I am not in L\out....I put it on its on list so I will scan it for awhile and see if something happens. I was wondering about a better antenna, but before I invest in one, thought I should check and see if I was missing something on the programming. I pick up the bus barn and it is about the same distance from me. I am about 3 miles from the sheriff office, so thought I should be able to pick them up. I will scan for one channel and see if anything happens...Thanks again for helping.
bharvey2
One thing I did notice in looking at the database for your area is that there are both county and statewide frequencies. Do you have both sets programmed in to your scanner? It could be that the statewide system is favored.
