Can someone help me program EDACS on the 500?
stlouisx50
Mountain Grove, MO (Texas County)
I was wondering if someone would please take the time to post step by step how to program EDACS into the 500.
I think I did it right but I am not 100% sure. The reason I ask is that it seems to search the trucked frequencies but when I hit manual on a stored talkgroup the talkgroup seems like it has an open carrier at the end of the transmission that does not unkey. Also I hear the end tones very very faintly at the end of the transmission. Also I thought I'd program the BC296D with the frequencies under Site 04 below just in scan mode rather than Trunk Mode to see if the 500 would miss anything and did notice that there was morse code on 09 854.93750 that the 500 missed.
The following is what I am wanting programed in: (Site 04) http://www.radioreference.com/apps/db/?sid=904
Also if there are any other settings that need to be changed in the glob please let me know. I appreciate all the help I can get.
Stlouisx50
stlouisx50
I have noticed that will also stick on a talk group and the sound once its stuck sounds like the mic is open, however you can hear the talk group talking through the open carrier. An example is like when 2 units key up at the same time on a repeater.
The 500 will stick on the talk group until scan is pressed again.
