One of the things that I like to do from time to time is perform a search with my radio, under computer control, and have it log activity. I will go back and check the History Log and see what sort of subaudible signalling has been used. Some of the following are analog and have a PL/CTCSS or DPL/DCS code listed. Others are digital and have a Color Code associated with them. There is even a NXDN in there with a RAN listed. I didn't include an frequencies that have no subaudible signal with them. They could be legitimate signals, using carrier squelch or they could be inter-modulation or "mixing". Since I was not personally monitoring each transmission logged, I excluded them. There are some that are logged that are only 7.5 kHz apart, like 151.9400 and 151.9475 that list the same subaudible code. It is possible, perhaps even quite likely, that it is from the same source of signal.
These were logged using an omnidirectional antenna at about 40 feet above the ground. I am located in Rosemount MN 55068.
Since some people are finding themselves at home due to COVID-2019, this might be a fun exercise to determine who is using what frequencies and subaudible signalling.
So, with that in mind, who is using the following frequencies?
150.905000MHz Color Code 1
150.935000MHz Color Code 1
151.085000MHz RAN 48
151.505000MHz CTCSS 151.4Hz
151.550000MHz DCS 047
151.760000MHz DCS 115
151.782500MHz DCS 115
151.820000MHz CTCSS 67.0Hz
151.895000MHz CTCSS 192.8Hz
151.940000MHz DCS 115
151.947500MHz DCS 115
152.367500MHz CTCSS 186.2Hz
152.442500MHz Color Code 6
152.930000MHz CTCSS 107.2Hz
152.982500MHz Color Code 7
153.072500MHz Color Code 10
153.110000MHz CTCSS 71.9Hz
153.455000MHz CTCSS 162.2Hz
153.590000MHz Color Code 5
153.612500MHz Color Code 6
153.650000MHz CTCSS 156.7Hz
153.815000MHz CTCSS 156.7Hz
153.882500MHz CTCSS 94.8Hz
154.025000MHz CTCSS 179.9Hz
154.205000MHz CTCSS 146.2Hz
154.310000MHz DCS 116
154.325000MHz CTCSS 186.2Hz
154.325000MHz CTCSS 136.5Hz
154.400000MHz CTCSS 186.2Hz
154.415000MHz CTCSS 118.8Hz
