Can You Identify The Following Frequencies?
JASII
Memory Capacity
One of the things that I like to do from time to time is perform a search with my radio, under computer control, and have it log activity. I will go back and check the History Log and see what sort of subaudible signalling has been used. Some of the following are analog and have a PL/CTCSS or DPL/DCS code listed. Others are digital and have a Color Code associated with them. There is even a NXDN in there with a RAN listed. I didn't include an frequencies that have no subaudible signal with them. They could be legitimate signals, using carrier squelch or they could be inter-modulation or "mixing". Since I was not personally monitoring each transmission logged, I excluded them. There are some that are logged that are only 7.5 kHz apart, like 151.9400 and 151.9475 that list the same subaudible code. It is possible, perhaps even quite likely, that it is from the same source of signal.
These were logged using an omnidirectional antenna at about 40 feet above the ground. I am located in Rosemount MN 55068.
Since some people are finding themselves at home due to COVID-2019, this might be a fun exercise to determine who is using what frequencies and subaudible signalling.
So, with that in mind, who is using the following frequencies?
150.905000MHz Color Code 1
150.935000MHz Color Code 1
151.085000MHz RAN 48
151.505000MHz CTCSS 151.4Hz
151.550000MHz DCS 047
151.760000MHz DCS 115
151.782500MHz DCS 115
151.820000MHz CTCSS 67.0Hz
151.895000MHz CTCSS 192.8Hz
151.940000MHz DCS 115
151.947500MHz DCS 115
152.367500MHz CTCSS 186.2Hz
152.442500MHz Color Code 6
152.930000MHz CTCSS 107.2Hz
152.982500MHz Color Code 7
153.072500MHz Color Code 10
153.110000MHz CTCSS 71.9Hz
153.455000MHz CTCSS 162.2Hz
153.590000MHz Color Code 5
153.612500MHz Color Code 6
153.650000MHz CTCSS 156.7Hz
153.815000MHz CTCSS 156.7Hz
153.882500MHz CTCSS 94.8Hz
154.025000MHz CTCSS 179.9Hz
154.205000MHz CTCSS 146.2Hz
154.310000MHz DCS 116
154.325000MHz CTCSS 186.2Hz
154.325000MHz CTCSS 136.5Hz
154.400000MHz CTCSS 186.2Hz
154.415000MHz CTCSS 118.8Hz
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania
151.940 is a MURS channel, could be any business. The frequency that follows it most likely comes from the same source judging by the matching tone, just a +75 khz offset
stmills
Twin Cites Area MN
154.025000MHz CTCSS 179.9Hz Polk County WI Fire
154.205000MHz CTCSS 146.2Hz Chicago County Fire
154.310000MHz DCS 116 St. Louis Park Fire
154.325000MHz CTCSS 186.2Hz St. Croix County
154.325000MHz CTCSS 136.5Hz Wright County Fire
154.400000MHz CTCSS 186.2Hz Pierce County WI Fire/ Le Sueur Fire
154.415000MHz CTCSS 118.8Hz Edina Fire
JASII
Memory Capacity
Here are a few more:
150.965000MHz Color Code 1
151.842500MHz CTCSS 79.7Hz
152.390000MHz CTCSS 127.3Hz
152.870000MHz DCS 624
152.877500MHz DCS 223
153.395000MHz CTCSS 107.2Hz
154.070000MHz CTCSS 118.8Hz
154.100000MHz CTCSS 136.5Hz
154.190000MHz CTCSS 192.8Hz
JASII
Memory Capacity
155.130000MHz NAC 480h
155.130000MHz NAC B7Fh
155.535000MHz DCS 712
155.550000MHz CTCSS 179.9Hz
155.640000MHz CTCSS 131.8Hz
155.655000MHz CTCSS 186.2Hz
155.745000MHz CTCSS 186.2Hz
155.955000MHz CTCSS 186.2Hz
155.962500MHz CTCSS 79.7Hz
stmills
Twin Cites Area MN
155.130 NAC 480 Pierce County WI Law 1
155.535 713 River Falls PD 2
155.550 179.9 Polk County WI Law 1
155.655 186.2 Pierce County WI Law 2
155.745 186.2 St. Croix WI Fire EMS Paging
155.955 186.2 Hudson WI PD 2
JASII
Memory Capacity
Some UHF. Specifically 453.0000-453.9875.
453.100000MHz RAN 32
453.400000MHz DCS 251
453.600000MHz Color Code 1
453.725000MHz Color Code 9
453.850000MHz CTCSS 136.5Hz
453.875000MHz Color Code 1 UID 712
453.900000MHz Color Code 11
453.950000MHz
stmills
Twin Cites Area MN
453.100000MHz RAN 32 M Health Fairview - University Security
453.600000MHz Color Code 1 Apple Valley DPW
453.725000MHz Color Code 9 City of Edina
