ProScan: Can't clear UID Log
garys
Central Texas
I generally don't use UID, but I'm trying to sort out who is using a specific TG on the GATTRS system.
I selected all rows, clicked on "Delete Selected Rows." The program asked if I was sure, I clicked OK and nothing happened. I was able to clear the History Logging screen with no issue.
Am I missing something?
garys
Central Texas
ETA: I just closed and restarted the program it the UID screen cleared. I have no idea what happened as I did that a few other times over the last couple of day.
It's set up differently for the SDS. I found it by moving columns around in the UID Logging screen and I don't have it (actually they) saved. I can't get the program to select all and delete for some reason.
Not sure if that's what he is referring to
garys
Central Texas
None of those were checked. I cleared it by closing and restarting the program, but am still at a loss.
Hi Garys:
On "UID Logging/Recorder or Recorder" scroll to the right you will see "SAVE" any that are check uncheck.
Al
U.S.A.S.A.
ProScan
Software Provider
Ontario, Calif.
It shouldn't happen if this option is checked.
It's the same for all scanners that supports UIDs. You probably dragged the columns to different position on a certain instance.
You should be able to if the 'Save' cells are unchecked like in this image.
garys
Central Texas
Thank you, Bob. I didn't use logging at all before this weekend. I've been trying to sort out UIDs for a system I listen to, so it's all new to me.
