I don't know about other programs but Scan75 sets it's own port control settings.
On my PC when I look in Device manager when Scan75 is not running I have default values of:
Rate: 9600, Bits: 8, Parity: None, Stop Bits: 1, Flow control: None
RX Buffer: High (14), TX Buffer: High (16)
When Scan75 is running device manager still shows these settings.
However Scan75 sets and uses the following: ( var_name = def_var_name). I have never understood why Device Manager shows default values even when different values are being set by a program.
'Serial Port Control Constants and Variables
Public Const def_port_name As String = "?" 'default start port
Public Const def_port_rate As Integer = 57600 'default port bit rate '
@A00
Public Const def_port_parity As Parity = Parity.None 'default port parity
Public Const def_port_data_bits As Integer = 8 'default port data bits
Public Const def_port_stop_bits As StopBits = StopBits.One 'default port stop bits
Public Const def_port_timeout As Integer = 500 'default port timeout ms
Public port_name As String = def_port_name 'current com port number
Public port_name_last_used As String = "none" 'com port used in last program run '
Public port_rate As Integer = def_port_rate 'com port rate
Public port_parity As Parity = def_port_parity 'com port parity
Public port_data_bits As Integer = def_port_data_bits 'com port data bits
Public port_stop_bits As StopBits = def_port_stop_bits 'com port stop bits
Public port_timeout As Integer = def_port_timeout 'com port timeout
With SerialPort1
.PortName = port
.BaudRate = port_rate
.DataBits = port_data_bits
.Parity = port_parity
.StopBits = port_stop_bits
.Handshake = Handshake.None
.WriteTimeout = port_timeout
.ReadTimeout = port_timeout
.NewLine = vbCr
.Encoding = Encoding.ASCII
'.RtsEnable = False 'did have True but not required - 06 May 22 '@A25
'.DtrEnable = False 'did have True but not required - 06 May 22 '@A25
So what I suggest you try is setting in device manager the usual default values I list above.
For Putty set the values (if available) to those Scan75 uses. NOTE! Only set Carriage Return and not Carriage Return & Linefeed.
Some other simple commands you can try are: VOL or SQL
Lastly Scan75 creates a "scan75-runlog.log" which contains basic log and error information which may be of help.
ALSO with Scan76 NOT running edit the "scan75-ini.ini" file and look for these lines:
# Log File Setting - Changes valid for next run only - size excluded!
ini_log_flag=False
Change ini_log_flag=False to ini_log_flag=True
Now run Scan75 and then close the program. The log file will contain a more detailed trace of what is going on.
The lines in the log for a working connection / scanner will look like these:
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707156 1598707156 -> Startup of 1.3.1.0
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707625 469 -> <= Read_Ini_Data()
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707625 0 -> => Notepad_Data_Read()
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707656 31 -> <= Notepad_Data_Read()
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707671 15 -> => SerialPort_Get_PortList()
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707687 16 -> Detected Serial Ports: COM5 COM4 COM3
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707703 16 -> <= SerialPort_Get_PortList()
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707718 15 -> => SerialPort_Try_Ports()
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707750 32 -> => SerialPort_Try_Port(COM5)
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707765 15 -> => SerialPort_Setup(COM5)
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707781 16 -> <= SerialPort_Setup(COM5) = OK
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707796 15 -> => SerialPort_Port_Open(COM5)
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707875 79 -> <= SerialPort_Open(COM5) = OK
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707875 0 -> => SerialPort_Test_Port_For_Device(COM5) with MDL
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707906 31 -> => SendCommand(MDL)
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707921 15 -> => SerialPort_SendData(MDL)
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707937 16 -> <= SerialPort_SendData(MDL) = OK
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707953 16 -> => SerialPort_GetResponse(MDL)
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598707968 15 -> => SerialPort_ReadLineData()
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598708000 32 -> <= SerialPort_ReadLineData(MDL,UBC75XLT) by READLINE
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598708000 0 -> <= SerialPort_GetResponse(MDL) = MDL,UBC75XLT (using:READLINE)
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598708031 31 -> <= SendCommand(MDL) = MDL,UBC75XLT
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598708046 15 -> Port Used: COM5 (READLINE) and UBC75XLT
03/03/2025 09:28:27 (GMT:03/03/2025 09:28:27) 1598708062 16 -> <= SerialPort_Test_Port_For_Device(COM5) with MDL = MDL,UBC75XLT
03/03/2025 09:28:28 (GMT:03/03/2025 09:28:28) 1598708734 672 -> => Model_Get()
03/03/2025 09:28:28 (GMT:03/03/2025 09:28:28) 1598708734 0 -> => SendCommand(MDL)
03/03/2025 09:28:28 (GMT:03/03/2025 09:28:28) 1598708750 16 -> => SerialPort_SendData(MDL)
03/03/2025 09:28:28 (GMT:03/03/2025 09:28:28) 1598708765 15 -> <= SerialPort_SendData(MDL) = OK
03/03/2025 09:28:28 (GMT:03/03/2025 09:28:28) 1598708796 31 -> => SerialPort_GetResponse(MDL)
03/03/2025 09:28:28 (GMT:03/03/2025 09:28:28) 1598708812 16 -> => SerialPort_ReadLineData()
03/03/2025 09:28:28 (GMT:03/03/2025 09:28:28) 1598708828 16 -> <= SerialPort_ReadLineData(MDL,UBC75XLT) by READLINE
03/03/2025 09:28:28 (GMT:03/03/2025 09:28:28) 1598708843 15 -> <= SerialPort_GetResponse(MDL) = MDL,UBC75XLT (using:READLINE)
03/03/2025 09:28:28 (GMT:03/03/2025 09:28:28) 1598708875 32 -> <= SendCommand(MDL) = MDL,UBC75XLT
03/03/2025 09:28:28 (GMT:03/03/2025 09:28:28) 1598708906 31 -> <= Model_Get(UBC75XLT)
Any errors (none above) should be logged.
To not bore the people here may I suggest you Email me at: scan75 AT nick-bailey DOT co DOT uk
You can attach the log file and I'll look to see if there is any useful info contained in it.
Nick
