I'm setting up a new "personality" for my SDS150 for an upcoming trip.
I have the Favorites List and the Systems. Everything scans fine.
Because it's new, the colors are the default and I want to changed them. For some reason, probably related to the problem I'm having reading the profile I couldn't upload the new display colors to the scanner. I was able to do that using Sentinel, but I want to save them in Proscan.
When I tried to read, I selected the file I created and went through the process.
I got the following error message.
The problem is that there is not file with that name. It doesn't show up in the Proscan directory. It should read
There is also no .cfg file in that directory. Some of my other files also don't have a .cfg file, but I don't know if that's problem.
I don't know why Proscan appends the "TEST PROFILE" to what I select and I can't get it not to.
This is what the "Select Profile" window shows,
That's the file I selected, but not what the error message showed.
I uninstalled and reinstalled a fresh download with no change.
I tested my SDS100 and got a similar result with this being the first line,
I'm at a loss.
Error reading from the scanner
System.IO.DirectoryNotFoundException: Could not find a part of the path 'G:\Documents\ProScan Files\SDS150TST\TEST PROFILE\profile.cfg'.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost)
at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost)
at System.IO.File.InternalWriteAllText(String path, String contents, Encoding encoding, Boolean checkHost)
at System.IO.File.WriteAllText(String path, String contents)
at Profile_Editor.ProfileEditor.FrmProfileEditor.ScannerRead(String Drive) in C:\Users\Bob\Documents\Visual Studio\Projects\Profile Editor\FrmProfileEditor.vb:line 2813
G:\Documents\ProScan Files\SDS150TSTprofile.cfg'.
System.IO.DirectoryNotFoundException: Could not find a part of the path 'G:\Documents\ProScan Files\SDS100TEST\TEST PROFILE\profile.cfg'.
I'm at a loss.
