Case for Pro-107
jperonto
Has anyone found a case for the iscan that fits well? The folks at Scanner Master responded to my question whether they would make a case for this scanner with "As of right now we don't have anything in the works for a case..."
I will be traveling with the scanner soon and would like some protection for it. Let me know if you have found a working solution.
iMONITOR
Silent Key
S.E. Michigan
I've been looking. A few camera cases come close. I bet it would fit into one of those long-cigarette case pretty good. It's about the same size.
jperonto
Sadly we don't have a Big Lots in our city. I am looking for older cell phone cases which are close in size and shape of the iscan.
yfdgricker
Youngstown, Ohio
I have my Pro107 in some type of case manufactured by Nite Ize. It's a black expandable case that is just wide enough for the Pro107 and it has a metal heavy duty belt clip with a snap to keep it on your belt. The belt clip part can also hold the scanner upright on a desk. I don't know if they still make this particular case. There is no identification number for it. I've attached a couple of pictures if that helps.
jperonto
Greg,
Thanks for the great info and pictures. Thank you also for showing that I am not alone in the use of the RS 800MHz antenna with the iscan.
Jeff
K7CAR
Monroe, WA
Go to any national chain store like Wallmart, Target, K-Mart etc. and check out the camera cases. You shouldn't have any problem finding a case for under $10 that will work. I was at the Dollar Store the other day and there were cases that were made to fit Ipods and Cell phones that were almost big enough to work. I have a Garmin GPS case that I bought several years ago for my 60CSx and never used, so that's working out perfect.
wkroitzsch
Kohler, WI
I found a Magellan sport trac GPS series at Fleet Farm for $11.00. P/N 980630-01 this fits great and has a clear plastic screen cover so you can see the LCD display. BUT you have to put it on upside down so therefore the belt clip is inop ,,,,it wants to swing upside down.But if you are looking for protection and style this works. Other than that once you slide it on and off a few times it acts like it was made for it....once I figure out how to put pics on here I will upload them......again this is a great little scanner. Happy Scanning.........
