Hey - Corbin...
If you were using CB in, say the early to mid 80's, you were still in the time period when background RF from all emission sources was still relatively low. These days, with RF saturation from 540Khz to 2.4 Ghz and above, the background RF on this planet is 6 times higher on average than it was back when you were active in CB. Taking it back even further, our family used CB for business operations from 1958 to 1970 using legal AM power and a HyGain CLR II base antenna and Antenna Specialists mobiles. Back in those days the background RF was negligable compared to today. On days when skip was not present, our base station could reach MOBILES 30 to 40 miles away and base to base of 60 miles or greater. Yes, those WERE the good old days. Now, in 2006, the background RF saturation is so bad that routine communications in simplex mode are roughly 1/2 to 3/4 the distance that were commonplace two decades ago on just about all frequencies in use. The technology companies all want their profits and are selling systems with higher and higher frequencies. This is creating an RF envelope around the planet and is degrading all communications systems. Remember, each time a transmitter comes on, there are harmonic emissions coming out of that same transmitter (well below main carrier strength, but present none the less). ALL of those RF emissions beat with other RF transmissions to form sum and difference frequencies which in turn beat with yet other RF signals and so on... this background RF saturation is what is creating range issues and there does not seem to be any way to control it except to throw more money at the problem and still come up empty in most cases.
The good old days? Yup - gone forever and in it's place, unreliable communications because of 'technology' and everyone in the industry wanting their fair market share without much responsibility to own up to the problem. So the next time that you use your cell phone, just remember that the tower that you are operating off of is probably creating a situation that is cutting down the range of an 800 mhz Police portable somewhere... but that is the reality of RF saturation these days.
