CB install in Expedition
I made these two CB antennas from the following parts - EMWAVE X-nut base for NMO mounting, aluminum tripod adapter (1/4"-20 female to M6 -1.0 female thread) and President New Virginia antenna, and a Cobra HG antenna with female 1/4"-20 to male M6-1.0 adapter (see photos). Screwed then together and total length is just under 20". The President antenna is not adjustable, so I can't trim it to dial in VSWR. The Cobra is trimmable for VSWR. What do you all think? Will they work (< 1.5 to 2.0 VSWR?).
Looking at the President antenna whip, it looks like the loading coil is in the base, so if you did everything right, it will probably tune up somewhere close to the CB band, but you'll need to figure in the additional length of the adapter.
The Cobra looks like it's got a coil in the base, so probably same as above.
So, it might tune up, but you'll probably have to do some adjusting.
I have a Laird C27S for highway driving, but I need something short like this to get into and out of my garage each day and airport parking decks (96" max vehicle height) when driving around town. Distance communication not an issue in town. But, I'm betting installing this in the center of the roof of my vehicle on an NMO mount will give adequate reception in town (2-3 miles). Hoping it works. Let me know what you think.
An antenna that short is going to be a very poor performer. You can take an antenna that really wants to be 108 inches long and cram it into 20 inches. As the antenna gets shorter, the performance is really going to drop.
Will it work for receiving over 2-3 miles? That depends on the performance of the transmitter. If it's someone else with a really short stubby antenna, it's going to be a real challenge. If they've got proper antenna, it might work if the physics gods are smiling upon you.
slowmover
Fort Worth
I understand the desire, but radio means one makes some adjustments. Kick the sullen teenager out of the drivers seat. A decent antenna is the definition of performance. (5’, IMO).
niceguy71
Massachusetts
I appreciate the input. I am going to move forward with installing the NMO roof mount. Based on the input from mmckenna, I think all will be well.
Okay, with the NMO mounted, next subject... I made these two CB antennas from the following parts - EMWAVE X-nut base for NMO mounting, aluminum tripod adapter (1/4"-20 female to M6 -1.0 female thread) and President New Virginia antenna, and a Cobra HG antenna with female 1/4"-20 to male M6-1.0 adapter (see photos). Screwed then together and total length is just under 20". The President antenna is not adjustable, so I can't trim it to dial in VSWR. The Cobra is trimmable for VSWR. What do you all think? Will they work (< 1.5 to 2.0 VSWR?). The tripod adapters are the big unknown, only a half inch or so thick, but it may throw everything else off. I need to remove powdre coating in the threads, so they conduct current. Currently no continuity with VOM.
I would love to hear how that Laird C27S works when you get everything done and get some experience with it.
funny how things work... I just made a video two hours ago on how a whippy antenna will not be any problem for a garage door and here I am reading your post... funny how it works.
for everyday use in your garage I don't think you will have ANY PROBLEM AT ALL those Laird C27S bend a lot and it won't hurt them... as for parking garages if you stand on the sill you can probably reach it and just unscrew it and put the antenna in the vehicle until you leave... they sell a little cap that screws on the NMO mount.
my video.... BTW my hobby is making TERRIBLE Video's and this is one of my worst!
niceguy71
Massachusetts
WSHH591 did you get the nmo mounted on the roof? And if so how does it do for going into and out of the garage??? I'm sure it's goes in and out perfectly fine?
When you get it done give us an update
WSHH591
Oregon
Sorry... the project is being delayed. I need to get the antennas working and a run power line, then drill the hole and mount the antenna. Just trying to fit this is in with work and family commitments. Likely late Spring if I can find the time. The shorter 20-inch antennas I am assembling will clear my nine-foot garage door. The Laird 52" antenna will not, but I'm sure it will bend on the spring without a problem.
niceguy71
Massachusetts
You have a 9 foot door??? Don't waste a minute on the short antenna.. the 52 inch laird will bend a little and pop right in and out... You saw my video above . I have an 8 food door and a 57 inch whip on a 4 inch magnetic base..... You will not have any problems at all... Just carry the weather cap for parking garages ... Other than that the laird will work out 24 /7 you won't even notice it going in or out of the garage.... And it being bent a little while in the garage won't effect it... It will still stand up straight when your not in the garage.
Installs take months... Always seems you have to order another part and wait for it .. and the CB install always gets pushed back for other springtime projects.
slowmover
Fort Worth
My install now spans two Presidential Administrations.
Takes what it takes.
