CB radio installation in a 1998 Volvo wagon
Those are all 800MHz antennas.
Left to right:
Larsen NMOSPEC-800 5.4dBi
Motorola branded 800
1/4 wave 800.
The Larsen is going to get you the most metal in the air, but as Jon said, it's going to be a very poor performer.
But, you've got something to try. See if it works well enough to do what you want.
Left to right:
1/4 wave 800.
Thanks for the information. Could any of these antennas be modified for CB use? Or could I build an antenna with the parts from these?
None of them can really be modified for CB unless you found a 108 inch long whip that would fit in place of one of the whips, but that isn't going to happen.
NMO27 really is your best bet.
Question about grounding; I am going to use a 2 wire trailer harness disconnect in this installation. That will involve cutting the factory wire from the CB body leaving about a foot, then connecting the two wire disconnect piece. My plan then was to run the ground wire immediate to the chassis, while running the power wire through the firewall and to the positive battery terminal. I figured I would splice the in line fuse somewhere up near the battery, but somewhere I could tuck it out of the way from moving parts. I plan to use quality crimp connectors for all the splices and will also use heat shrink tape around any splices.
Do you think grounding after the quick connect piece is a bad idea? We're only talking about 12"-18" from the radio chassis to ground. The power wire will be 5-6'.
Rred
Here and there
Grounding to the chassis "at" the radio can work, if you have a solid electrical ground from that point to the common ground point for the battery. Instead of measuring or gambling it can be simpler to just run both wires to the battery. You could check the quality of that ground point with an ohmmeter, voltmeter, your choice, with long enough leads. (Easier to run the wire.(G)
There are also split thoughts about fuses. Some radio manufacturers want fuses in both power lines, located right up by the battery. This is partly to prevent a problem if one of your lines is not at a perfect 0/12 volts and you get a voltage fault (loop) in the unfused one. Others say this is not a real-world concern. See what your car and radio makers each say, pick what suits you best.
A quality wiring job (no twist-and-tape) with good chafe protection probably counts more than everything else.
RFI-EMI-GUY
Ground at the chassis as close to the radio as possible . Grounding at the battery terminal isn't recommended because of potential chassis ground lead fault conveying starter current into the radio and the coax. Could set fire to the interior and headliner.
Sent from my SM-T350 using Tapatalk
Short ground connections are a good way to bleed off noise. Power wires can act like antennas.
Ground the radio with as short a wire as possible. If you still feel the need to run to the battery, that's up to you.
Ok, so I do want to ground it as quickly as possible and I believe I have a suitable ground not that far away from the radio. That said, will I severely compromise my ground if it is grounded AFTER the quick disconnect pictured below? Or does the ground have to run straight from the radio to the grounding point?
RFI-EMI-GUY
When you use those quick disconnects, be sure the positive wire from battery is the female protected side. I have seen those spliced the wrong way.
I didn't realize there was a "side" to this; I assume red would be the side to wire to the battery?
RFI-EMI-GUY
When you pull the connectors apart, there will be an exposed terminal on one red side. You want that wire going to the radio not the battery.
Project25_MASTR
Millennial Graying OBT Guy
Texas
98% of all vehicles on the road in North America are Negative chassis ground. A little electrical common sense explains the reasoning of manufacturers.
If you have a DC grounded antenna, then a properly install antenna mount will be grounded to the chassis. If you take both leads to the battery, you have created a potential ground loop. If you lose the chassis grounding between the negative post and chassis, current from all other loads will now flow down the antenna coax through the radio and to the battery. This is why the negative fuse becomes important.
Of course, grounding to chassis with the radio eliminates the potential difference without requiring extra hardware…that's why it is the traditional method of powering radios through the American manufacturers.
Thanks everyone for their responses above and on this thread in general.
I'm getting ready to run the antenna wire down the door pillar and I have two questions before I do that. First, please see the attached picture. There is a wire that powers the sun visor mirror light, the plugged connector for which is visible in the photo. Since I really don't need to have a light up mirror in my passenger seat, should I disconnect that plug? The coax is going to run right along side of it and pass through the dashboard at the exact point where that plug is. I want to do everything I can to eliminate noise from the cars electronics. Second, I have about 2 1/2" feet of coiled coax left in this wire, based on what was said higher up in the thread, I plan to loop it into 2 or three 6" diameter loops, zip tie it, and leave that material in the headliner. Would it be a good idea to leave these zip tied loops right under the NMO mount or should it be off to the side? Thanks.
RFI-EMI-GUY
No need to disconnect that mirror lamp plug. It is probably not a noise generator and the coax shield is there to protect from that. I would be hesitant to leave hoops of coax in the headliner as it will weigh it down possibly to droop, and because it may create an annoying rattle. Leave just enough service loop in case you need to loosen the NMO base in the future.
2 1/2 feet isn't much.
I agree with RFI-EMI-GUY, leave some slack under the NMO mount just in case you ever need to remove it. Not much, but a few inches. I've never needed to remove an NMO mount, but there is also no point in pulling the cable tight. A bit of slack isn't going to hurt anything.
For the slack, it would do better under the dash near the radio. More than likely any issues you have with the coax will be at the termination where it connects to the radio. Leaving some slack so you can get the connector out from under the dash for repair or re-termination is a good idea.
Ok so I just got my Larsen NMO27 in the mail. All the rest of the set up is complete. All I need to do now is drill the roof hole and run all the cables. I have a quick questions about the hole drilling and so forth;
After I drill the hole, should I shoot a little primer on the expose metal of the roof? I'm concerned about rust, but I also don't want to do anything that would hurt the antennas functionality. Also, I asked further upthread where I should put the small coil of slack that I will have in the antenna cable. About 2 1/2" zip ties into a 6" coil per a suggestion from others. Should that go right under the NMO base or off to the side. I'm not concerned about weight as my headliner is very strong and there is a support buttress molded into the headliner itself right near the installation point. Thanks for all your help this far. Will post pics of completed install soon.
RFI-EMI-GUY
If you used the special NMO hole saw there should be a band of exposed metal for the antenna base to ground to. You want an electrical connection at the base, so exposed metal is good. I would use some dielectric grease from an Auto parts store to provide water proofing of the O ring and protection from rust.
After installing the base, use an ohmmeter to verify continuity between the outer shield of the coax and the vehicle body. You should have zero ohms.
I'm not going to use one of those special drills, just a brand new Irwin 3/4" bimetallic hole saw. I will have an assistant inside the car holding up a backer board with the headliner removed. I've tested the hole saw and it cuts an accurate and a very nice hole. So, I know there will be a portion of the sheet metal (the inner rim of the hole) that will def. be exposed metal; what other metal should be exposed or what other metal is exposed using one of those special NMO holesaws?
RFI-EMI-GUY
The NMO saw cuts a thin strip of exterior paint, just enough to mate with the brass threaded portion of the NMO base that is just inside the O ring. You can sand and expose this small ring. Then put dielectric grease on the exposed metal and o ring before tightening down.
