CBP and ICE frequencies
N1XDS
ÆS Ø
What frequencies are they using now? I know search "Google or scan the VHF band on my scanner" I know they use a few frequencies around here where I live in Central Georgia. What other frequencies are they using? I'm currently updating my programming file for my Uniden 536HP scanner.
Edit...I already have the frequencies listed on the MT-Fed files website.
Please no back and forth with everyone let this topic stay on point please.
nd5y
Wichita Falls, TX
ecps92
Taxachusetts
Most Federal Agencies [Not all, but Most] are conventional
IF you want to go the One Freq TRS route, to capture Radio ID's - fine,
but all that is needed is basic program entry as P25
Should these frequencies be programmed as a trunk system or P25 one channel?
N1XDS
ÆS Ø
Here are the following frequencies I am picking up as follows in P25 digital mode in the Byron area.
ICE? 169.9375 NFM NAC B10 LNK/DAT
ICE? 172.4125 NFM NAC B10 LNK/DAT with encryption when in use
CBP AIR Four 169.1625 NFM NAC 293
DEA 170.6500 NFM NAC 156
BATFE 167.1625 NFM NAC 650
iMONITOR
Silent Key
S.E. Michigan
I think the easiest way is to use MENU, Location, Zip Code, Radius (set to 2.0 miles), then turn off all Services except for Federal. Connect to a PC using ARC536 or ProScan logging and let it run 24/7 for a few days and let it do all the work, no guessing! Works great!
ecps92
Taxachusetts
Seems to far for NC/SC or even the MO info I had
But...
Okefenokee National Wildlife Refuge
has had some fires lately and that Freq/NAC have been used in FLA for Aerial Ops...just a WAG
Somewhere in Houston or Bibb.
N1XDS
ÆS Ø
I just picked up 170.6625 NAC 167 NFM no activity just lot of LNK/DAT and II looked on Chris P's website and only saw DEA NAC 156.
ecps92
Taxachusetts
a Freq or NAC Alone do not identify the agency.
Sometimes even the NAC/FREQ can help, but not always
What part of GA was this heard from...
N1XDS
ÆS Ø
167 NAC is usually FBI.
On R/R Federal NAC codes listing it shows different users that is why I checked Chris website
NAC 167
Good point. Byron, Georgia
Picked up 173.100 NAC 167 NFM LNK/DAT (Byron, Georgia)
N1XDS
ÆS Ø
Could be, found an ancient archive list and [Pre-P25] it indicates 171.7750 for this site
That is what I found as well.
I'm picking up 173.100 NFM NAC 167 FBI? Encrypted.
CBP AIR ONE 168.8375 NAC 293 NFM
ChrisP
Portland, OR
Just FYI, the DEA and FBI are both part of the Department of Justice. Since the DEA is moving towards VHF everywhere, some of the frequencies they are using have come from various DoJ assignment pools of frequencies that can include those used in some ares by the FBI.
- Chris
