CBP freqs for Kingman area
N6RDT
USA
Looking for the frequencies most used by the Border Patrol in the Kingman area. Im sure they are P25. just need to know the freq and NAC code.
AZMONITOR
AZ
On those rare occasions that the BP uses radio in the Kingman area they are almost always encrypted.
ecps92
Taxachusetts
Why not post the info anyway. Just because it is ENC today, doesn't mean it will be ENC tommorrow. Pass them along and build the RR Database with the information [aka SHARE] :confused:
AZMONITOR
AZ
163.675 on Hualapai Moutain has been used by the BP.
N6RDT
USA
AZMONITOR, What is the input/tones or nac codes of the 163.675 repeater on Hualapai that border patrol uses?
AZ_RADIO
Northwest Arizona
Why do you want the Input and NAC codes ??? CBP is now DHS and uses 3 repeaters on Hayden Peak. They are 163.675, 163.625 (Not used very Often) and 173.6875. They also use the "ALLIANCE" repeater system on multiple MTN Tops, I believe it is on 167.800.
Enjoy
ecps92
Taxachusetts
NAC's are like PL Tones, we collect them ;)
As for the input, it helps when monitoring and if you happen to hear them on the input you know they are close by.
Nothing Suspect, but a few die-hard scannists looking for info that is kept close to the vest :D
BP and ICE seem to use a different NAC on each Repeater, but use a Common NAC for the input
of the Wide-Area Nets
CBP / BP and ICE are part of DHS, but still operate their own Radio Networks.
Sadly too many people are lumping all DHS Agencies under DHS [Parent Agency] vs listing them individually.
FPS is still FPS altho under DHS
USCG is still USCG altho under DHS
Yes they share common channels, but remain unto their own.
Enjoy
N6RDT
USA
Cbp
You still need the NAC code to listen on a scanner or you wont hear anything.
Arizona_Scanner
Phoenix, AKA HELL
Not true. So long as you have a digital scanner, you will pick it up, and the code will come up on the screen to save, or not to save. The value of having the NAC is the same as having a PL or DPL...it means you WON'T have to hear all of the intermod / interference that can come up on the frequency.
