CDF (CalFire) QuickCall
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
I'm looking to set my radio so that only my local department opens my radio via QuickCall. I am going to have two channels, one for receive all and one for just local stuff so I'm not woken up overnight for EVERYTHING.
Does anyone have a list available? I know one was started for the San Francisco South Bay area a while ago!
Regards,
-Frank C.
Eng74
Kern County, CA
If you have a newer Uniden with fire tone out you can decode the quick calls that you want. Set both tones to 0.00 and then indefinite for the time so you can write the tones down to program later.
kg6nlw
I do, but the tones are split A/B C/D and I can't reset between the two quick enough to get all 4 among other tones I would like.
Regards,
-Frank C.
kg6nlw
Exactly...Hence why I'm asking if anyone has a list...I know there was one floating around, maybe in excel?
Regards,
-Frank C.
Eng74
Kern County, CA
I know when Kern County was still on the 2+2 my 330 and 336 would not work on it. Once we went to the new VHF system and the new 1+1 they worked.
E5911
the lower desert
Does anyone know who makes the hi-speed 4 dtmf quick calls that Cal Fire is using in San Diego?
