cdm series last programmed info
sraider
Wood Lake, MN
If I have a cdm series radio read with the CPS software, will the software tell me when the radio was last programmed and what version of CPS was last used or any other info about the last programming?
sraider
Wood Lake, MN
So I found some info under radio information. It says what date it was last programmed. Under programming source latest, it just says CPS doesn't give version number Is there any other place to look?
Professional Radio CPS version R06.11.10 will only show you that it was last programmed with CPS, but not which version. It will show "codeplug version" is shown, but that isn't the same as the version of CPS that was used.
There may be a way to find out, but the only way I know of is to try programming it.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
My error on that. Even the very latest version only gives what programmed and not what version. It does give the Codeplug revision and last programming date.
