Need Help: TRX-1 Programming
Ubbe
Stockholm, Sweden
Using a paper clip instead of a proper antenna can be the difference that the attenuator setting are doing, and then you can set the attenuator only to those simulcast systems that doesn't seem to be received and keep full reception on the rest of the systems.
/Ubbe
Patrolman714
Myrtle Beach, SC
In a surprising update - I updated my second TRX-1 and copied the Horry County Configuration to it, and, It Works! It scans with the OEM and 800Mhz antennas attached. The configuration includes all of the Simulcast Scanner Settings that were suggested in this thread. Now, I am wondering what is going on with the TRX-1 that doesn't scan this system. Any suggestions?
pyeman99
Cornwall UK
Swap the SD cards & see what happens.
