CDM CDM1550 for Allstar using a Universal Radio Controller
kc2fwn
Rochester NY
Hello,
I have a Universal Radio Controller (URC - Universal Radio Controller v2.2 Technical Reference – G1LRO HOMEPAGE) and I have it configured for Allstar using a HampVoip, ASL3 on Pi4 and Pi5.
I have used 2 radios successfully, a Quancheng and I built a cable for a Leixen 898. Both work perfectly with my node configuration.
I've been trying to get a Motorola CDM1550 programmed to use the OHIS configuration, the same configuration I used for the Leixen.
The piout that I've found does not really work. The PTT, or Audio setting are not understood by the URC.
I tried this Pinout
TX/RX:
pin2-Tx audio
pin3-PTT
pin7-ground
pin11-Rx audio
I have not used pin8-COR out
The URC cannot activate the PTT, or it believes that the PTT is always on.
I would like to see who has configured this radio, or a CDM 1250 (almost identically) to work with Allstar and what interface you used.
Thank you for any help that you guys can give me.
Hector - KC2DWN
ff026
ff026
Did you set the PTT pin for active low? Reading the documentation for the link you posted it states the PTT relay goes low for activation.
