Cecil Co. Edacs
wildbillx
Cape May, NJ
Can someone who is able to track the system update the database? I have a good list of tg's started but only a couple identified.
maus92
OCMD
Slightly OT, but is anyone using the new Uniden firmware on the Worcester or Somerset systems yet? Is it need in those counties?
u2brent
OAMPT
KRWDPAXKRS1
RR DB Admins
Is RR working on a fix so folks can actually submit findings to these EDACS Extended Addressing systems. The TG's which apparently don't translate to AFS Format? The radios will only display the DEC #'s... Regardless of your display preference.
EXAMPLE TG :
DEC# 20 AFS# 00-024 - Unknown
DEC# 4225 AFS# N/A - FD/EMS Dispatch
Anyone?
troymail
Silent Key
You would need it to follow the ProVoice talkgroups on both.
Sent from my SM-G900V using Tapatalk
I know Somerset law enforcement are using ProVoice but most of that can be heard on the patch to FiRST. What other users are using ProVoice in Worcester and Somerset and roughly how many talkgroups are ProVoice?
wise871
N.W. Florida
EXAMPLE TG :
Anyone?
Seeing the same thing on the Florida SLERS. The RR database is having a hard time excepting the information. If you ever have to go back and edit, you will have to start from scratch.
Sent from my iPad using Tapatalk
DisasterGuy
Maryland Shore
There is (was) a plan for the Somerset TGS on the FiRST patch to be encrypted on the FiRST side at the request of Somerset. If they will continue with that plan in light of the Uniden PV option remains to be seen as the development took system owners by surprise.
There are a number of PV talkgroups on the Worcester system. These are mostly LE TAC talkgroups. Each municipal PD has a "channel 2" that is PV and the Sheriff's Office has a number of PV talkgroups however most of those are encrypted.
troymail
Silent Key
Curious why they talked about but then opted not to encrypt on FiRST.
Seems like the biggest issue with encrypting on the EDACS or FiRST side would be any potential expense involved - is there a cost or would something else stop them from now encrypting?
Seems like there is limited value in paying for the ProVoice option for the lower shore - even more so if the "system owners" decide they now need to encrypt. Listening may be short lived.
DisasterGuy
Maryland Shore
It would not be wise for Somerset to invest in encryption until they move to P25. They have used PV as a way to have privacy through obscurity.
You have less than 2 years until Worcester and Ocean City have migrated to P25. On both Worcester and Ocean City the things that really need to be protected are already encrypted using DES. Those same functions will remain encrypted with AES when the P25 cutovers happen. While TG structures will change you should generally see nothing more and nothing less go encrypted at least at the county level.
u2brent
OAMPT
KRWDPAXKRS1
Has anyone successfully monitored Cecil County EDACS?
Is it encrypted?
I have it on my 436 and with the new Firmware installed & Provoice Feature enabled ($49.99) it works just great.
Have not heard any E. Everything seems to be in the clear..
Did I mention It's Great!!!! Sound is clear, It's got lots of traffic..
Here is what I've heard in just the last 24 HRS.
Can We Please Get This Info into the RR DB? (See my earlier posted question)
DEC#s
Unidentified TG's
20 Unknown also AFS 00-024
21 Unknown also AFS 00-025
8321 Unknown
8578 Unknown
8705 Unknown
8707 Unknown
FIRE/EMS TG's
4225 Fire/EMS Dispatch
4226 FD/EMS Tac 6
4227 Unknown
4228 Unknown
4231 EMS Ops
4237 Unknown
4238 Union or Christiana Hospital?
4239 EMS Dispatch
LAW ENFORCEMENT TG's
4736 Unknown
4737 Rising Sun PD
4738 Sheriff
4745 Pd unknown town
4746 North East? PD
MUNICIPAL TG's
8450 Unknown
8451 Public Works
RADIO ID'S
6 ?
30 ?
801 ? Dispatch
802 Dispatch EMS?
805 ? Dispatch
806 Dispatch FD/EMS
807 ? Dispatch
809 Dispatch Sheriff
810 Dispatch PD
1505 ?
1525 ?
1531 ?
1606 ?
1631 ?
1645 ?
3289 ? EMS
3291 ? EMS
3292 Medic 392
3295 Medic 394
3510 Chief 4 portable
3511 Chief 4 mobile
3703 Rescue 4
3733 ? EMS
3771 ? EMS
3795 Ambulance 493
4804 ?
4818 ?
5501 ?
5520 ?
5711 ?
5731 ?
5741 ?
5793 ?
7001 ? PD
7019 ? PD
7156 ? PD
7161 ? PD
7175 ? PD
7201 ? PD
7219 ? PD
7247 ? PD
7608 ? PD
7609 ? PD
7616 ? PD
7622 ? PD
8506 ?
9041 ? PD
9050 ? PD
9052 ? PD
9057 ? PD
9061 ? PD
9065 ? PD
9074 ? PD
9078 ? PD
9082 ? PD
9117 ? PD
9501 ? PD
FIRE/EMS TG's
4236 Unknown
4243 Unknown
DisasterGuy
Maryland Shore
Unless something changed in the last two years CCSO and EPD have their own primary talkgroups. The remainder or the PDS share are talkgroup called "Towns".
u2brent
OAMPT
KRWDPAXKRS1
Keep 'em coming!!
4228 Fire Ops 8
4238 Union Hospital
Then
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Remember that verified talkgroups should go to the database; unknowns, as well as Radio IDs should be in the wiki. Questions about whether the DB can handle the extended addressing TGs should go to the Database forum.
I can set up the pages in the wiki for this if needed...Mike
u2brent
OAMPT
KRWDPAXKRS1
I have not attempted to submit anything regarding Cecil County, Someone else apparently has and they appeared and disappeared again & again, after seeing them for a day, POOF Deleted. Why? Wuz Up Wit Dat?
I'm just posting in the forum, unidentified's are OK here..
We've collectively already cleaned up some unknowns here.
A Wiki would be great!
DEC 16/AFS 00-020 PA Fire Interop Patch?
