The whole blocking thing is/was mostly moot. Before 1986 the broadcast TV band went to 890Mhz, the top of channel 83. In 1983 internationally that was changed and the band ended at 806MHz, channel 69. One could easily use their TV set, choose channels 80 to 83 on their mechanical analog TV tuner, adjust the fine tuning, and hear phone calls. Those tuners continued to be used for a decade or more even though TV didn't go there since the design worked and there were warehouses full of them. Frequency shifting, although designing for UHF can be tricky, is not a difficult thing. If one really wanted to they could build a converter to shift 870Mhz down to a range their radio supported. It's a common practice today, HF upconverters for Realtek dongles for example.
Of course in 2009 the TV band was shortened to 698MHz, channel 51, and will soon be shortened again to 608MHz, channel 36. (In the USofA)
