I would recommend getting a separate battery charger. Since one bad battery will make the whole set seem bad, you will first need to confirm that each individual battery is good. This is not possible by using the scanner to charge batteries. The La Crosse BC-900 is what I've been using for over a year with no problems, so I just bought another one. It has a test function that works great, each battery is on its own charging circuit and digital display. Most people would not recommend using the scanner to charge batteries since a malfunction or battery failure could very well destroy the radio and or cause a fire. Thomas Distributing has the BC-900 on sale right now for $38.97 regular $54.97, it comes with 4 AA and 4 AAA batteries. Good deal.
BC-900 Battery Charger Sale $38.97 La Crosse - LaCrosse BC900
Pages 18 and 19 of the manual specifically give instructions on recharging the batteries IN the scanner. If this can destroy the scanner why would they suggest recharging this way. I have a Panosonic charger but I believe it has a limit set for how long it charges batts. E.G., when I put new AA batts in it only charged for maybe two hours and then the solid light tells me they are done. But since the manual says it takes 16 hours for Ni-MH batts to charge, I took it out and put it back several times. I don't think that this is normal. What say you?
OK I googled Panasonic BQ390 which is the charger I have and here are two reviews from Amazon on two older chargers.
Jack Wang's Profile
Customer Reviews: 5
New Reviewer Rank: 183,739
Classic Reviewer Rank: 102,530
Helpful Votes: 390
Reviews Written by
Jack Wang (Waterloo, Ontario)
The Sony Power Charger can recharge 4 AAA or AA cells at a time. Unlike the Panasonic BQ-390 which I also used and reviewed, this Sony uses a timer to stop charging. The Panasonic BQ-390 has advanced circuitry inside to monitor charging through temperature, voltage drop, and the cell's internal resistance, so that you'll get more precise charging and less damage from overcharging of simpler chargers. Sony also offers a similarly advanced product, but this model is a cheaper timed model. It charges the 2100mAH cells for 8 hours straight, or 800 mAh AAA cells for 7 hours straight. If you charge a partially used cell, it will not detect when the cell reaches full charge, and might overcharge. It's best to charge a fully depleted cell with timed chargers.
Panasonic BQ390A - Battery charger - battery - rechargeable - AA - NiMH x 2 - 2100 mAh
Availability: Currently unavailable
38 of 38 people found the following review helpful:
A Fine Charger Set, July 4, 2004
The BQ-390 charger, with its pearlescent white finish and simple lines, is an attractively designed charger. If you were giving this as a gift to your girl friend, it will not look so geeky as the other Sony, Kodak or Maxell chargers you can find on Amazon.com.
Like the Sony Power Charger, it has advanced circuitry inside to monitor charging through temperature, voltage drop, or the cell's internal resistance, so that you'll get fuller charges and less damage from overcharging of simpler chargers. In other words, your NiMH cells will give you better performance as well as a longer service life. This breed of chargers also charge each cell individually, rather than in pairs. Less sophisticated chargers charge in series, so one cell in the pair may not receive full charge, while the other, worse, is overcharged. NiMH, unlike older NiCd's, does not tolerate overcharging. Because they have 3 times the capacity of NiCd's to refill, all at under 2 hours, you can see why chargers are so expensive, and why they're worth it.
Panasonic has recently shifted their cell production from Japan to China, so you might get Chinese cells in the bundle. Still, Sanyo and Panasonic are the 2 major NiMH makers, and you can't go wrong with either. (Sony and GE NiMH cells are all made by Sanyo.)
This charger will only accept 1~2 AAA cells at a time (but 1~4 for AA cells). If you need to charge 4 AAA at a time, look to the Sony Power Charger elsewhere on Amazon.com. It bundles 4 NiMH AA cells made by Sanyo for Sony, but charges more slowly, twice as long as this Panasonic. But that is also why it's somewhat cheaper.
So I guess I have the answer concerning my Panasonic charger.
