Charlotte County changes?
vinnienap
Punta Gorda, Florida
This is my list as of this morning. DEC is what you are wanting. HEX is for Motorola radios. If there is something in DESCRIPTION it has been confirmed. All 5 digit Talkgroups starting with a "6" are cross patched and are dynamic--thus change until they get everything swapped to the new system. Any of the 12 frequencies can be used as the control channel--enter them all as your control channels.
DECHEXDESCRIPTIONNOTES
11SO Dispatch 1
22SO Dispatch 2
33SO Dispatch 3
44SO Dispatch 4
10ASO Tac 1
11BSO Tac 2
12CSO Tac 3
13DSO Tac 4
14ESO Tac channel
2014SO Tac channel
2115SO Tac channel
2418SO Tac channel
2519SO Tac channel
201C9Jail
202CAJail
203CBJail
204CCJail
30112DSO Tac channel
30212Eposs so radio heard
30312FSO Tac channel
304130SO Tac channel
10013E9Poss airport
10023EAairport ops
105141Banimal control
12514E3
1301515Fire Dispatch
1302516Fire Dispatch 2
1305519Fire Tac 1
130651AFire tac 2
130751BFire tac 3
130851Cposs fire tac 4
130951Dposs fire tac 5
131051Eposs fire tac 6
1315523ARFF
132552DFire aining heard
1330532heard fire hazmat training
1345541EMS to Bayfront Punta Gorda Hospital
1346542EMS to Englewood
1347543EMS to Fawcett Hospital
1348544EMS to Bayfront Port Charlotte Hospital
1361551Aeromed
1364554
1601641
1666682Public Works
16716E1
1810712
1813715
185173Btransportation…bus
190176DWater Department
2601A29PG Police Disp
2602A2APG PD Heard
2605A2DPG PD Heard
2611A33PG Police Tac
2801AF1PG Fire Disp 1
2805AF5PG Fire Tac 1
How would I enter a frequency as a control channel. I can’t seem to find an option anywhere on the scanner (BCD992p2) or the ARC Pro software for that.
I have all twelve of the frequencies programmed into the system. Thanks, Vinnie
CoolBlue87GT
Punta Gorda FL
I have the Homepatrol 1, which only does P25 Phase 1. Now I've updated to the Uniden SDS100, ( Great radio ! ) Now I'm receiving the Phase 2 channels. I was receiving Charlotte county FL Fire, then it disappeared. I did an RR update today, I'm still not receiving Charlotte county Fire dispatch channel. Anyone know why that channel disappeared ?
I_am_Alpha1
Again, THERE IS NO PHASE 2 IN CHARLOTTE COUNTY! None what-so-ever. Everything is Phase 1. Bad info causes people to program radios incorrectly resulting in radios not working. Look at your display, it will show P25 proving you were given bad intel...causing you to purchase a $650 scanner when you possibly didn't need to.
Yes, SDS100/200 are better--I wanted to hate them, but they do work better on this system when I compared to HP1, 996, 436/536, & 396.
Charlotte Fire Dispatch is on TG 1301 and works fine...listening right now. I prefer to create my own favorite scan list versus using the master database. Go to the master database in Sentinel and find Charlotte County. Right click on it and click on append to favorite. Then edit favorite to your personal liking. Go over everything--frequencies and talkgroups to make sure they are correct. Write to radio and select your new list to scan.
CoolBlue87GT
Punta Gorda FL
Okay, interesting. I used discovery mode this morning on the SDS100, found 21 talkgroups - including 1301 and some others not listed on RR. I've added them to the favorites. Works great.
Now, the HP1, I'll go back and try to get it working again. I saw this on RR Charlotte County (Project 25) Trunking System, Various, Florida - Scanner Frequencies
Btw, I'm in the Kings Hwy & Midway area.
I_am_Alpha1
CoolBlue87GT
Punta Gorda FL
I have the database admins the correct info...took me a very long time to put it together. Others had to get their fingers in there and mess things up. Check the list I posted above and continue to search could be your best plan.
Thanks, Was wondering why it's not up to date.
Glennd333
I'm a resident of PGI and having the same issues as everyone else with BCD436HP. Nothing so far seems to help. Any suggestions?
Bolt21
Spark Chariot Driver
Punta Piñal
Using a higher-numbered squelch setting (like 7 or higher) is one thing you can try with your 436, reception wise.
Glennd333
Thanks Bolt but not any better. Is there anyone out there (in Charlotte County) that has a 436 and is happy with it's performance regarding CC Sheriff/EMS/PG Police?
wg21
I also live in PGI. Have been listening with BCD436HP for number of years. Could not get anything other than garbled transmissions. Bought an SDS100 and that works just fine.
Glennd333
Thanks for the info CoolBlue. Looking like the SDS100 is the way to go. Cha-Ching!
