Cheap scanner to stream with
scottybo14
Semmes, AL
What's a decent, but cheap, scanner to stream a feed to RR with? I have the Pro 106 but don't want it tied up to one freq. The signal will be analog.
I'd like to stick to Radio Shack since I have the programming cable. What others are compatible?
n5ims
That would depend on what you were attempting to stream. If it was conventional analog, a very old $5 thrift store scanner would do just fine. If it was one of the various trunked analog systems, you'd need to find a scanner that's compatible with that kind of system. Be aware that if the trunked system had been rebanded, you'd need a scanner that can work on a rebanded system. Often times these can be found for not much as well, but since they're newer, they may be a bit more than that $5 thrift store find.
Perhaps if you posted a link from the RR database (or gave us some specific information on) what you want to stream, we can give you some more specific information on a good scanner you could use.
Nasby
Ohio
If you want a PRO-163, go to digicircle.com. They have em' new for much less.
