Nice. It looks like that unit is $200 or less. I was thinking an actual Kenwood or icon radio would be cheaper, but this scanner may be lower cost. But I have heard that scanners have difficulty with NXDN trunking versus an actual NXDN radio.
Kenwood NexEdge system packets are tagged as from a trunked system.
A Kenwood NexEdge capable radio will not decode a system unless it has:
1. Been programmed by the system administrator with the system key
2. Has registered with the system.
3. Has a valid ESN/UID in the system if the system admin has set the trunked system up to control access that way.
So, buying a Kenwood NexEdge radio is -not- an option. Even if you program it as conventional, the radio will not decode trunked system packets.
I've heard that Icom radios will decode the packets in conventional mode, but it won't trunk track.
Really, your best option is the scanner. It'll be cheaper than the radio + software + cable + learning curve. Plus the scanner will have much more capability.
