Checking duplexer
FreddyM
Saskatoon,Canada
I'm not sure if I'm in the correct spot to ask this......
I have a sinclair duplexer Q2220E hooked up to a kenwood TKR-D710 repeater
At my disposal I have a NanoVNA meter and a 50 watt digital SWR meter
The duplexer ports are marked low pass and high pass
The repeater ports are marked Tx and Rx
I am transmitting at a lower frequency than I am receiving
Im wondering if there is a way to check how the duplexer and the repeater should be interconnected?
Is there a way for me to check the SWR on the repeater and if so how would I connect my meter?
Is there a way to see if the duplexer is tuned correctly with those 2 meters?
And just because the duplexer is marked low pass and high pass I have lost all faith in the company that sold
the equipment to me so I am assuming it might be marked incorrectly.
All help is appreciated>
The lower frequency (your repeater transmit frequency) ~should~ go to the low pass port on the duplexer.
The higher frequency (your repeater receive frequency) ~should~ go to the high pass port on the duplexer.
Ideally you want a spectrum analyzer with a tracking generator if you wanted to try tuning the duplexer.
Since it sounds like you just want to confirm what should be connected where, you could use the SWR meter connected to a proper 50Ω load, or at least a known good tuned antenna, and look at the power output. Look up the specs for the duplexer, it should show a maximum loss through it. You could could then connect the watt meter between the repeater transmitter port and the duplexer low pass port and compare the transmit output to the duplexer output. The manufacturer specs should tell you how much loss you should see.
If you see a whole lot of loss, then try checking the other port. Could be it's hooked up backwards or so far out of tune that the TX power isn't getting through.
Specs for that duplexer seem to suggest around 1.5dB of loss.
Duplexers are fragile, and if you think it may be out of tune, banged around, mistreated, or not hooked up right, I'd contact a professional to come out and tune it on site for you.
I would recommend not calling that company to tune your duplexer.
FreddyM
Saskatoon,Canada
Are you saying I should connect the SWR meter between the antenna and the duplexer antenna port first and than between the duplexer low pass port and the repeater transmit port and compare results?
I checked the SWR on the antenna with the VNA meter and it showed around 1 to 1.1 so that should work instead of a 50 ohm load
On my SWR meter it says 120 watt measurable range.
What if I exceed that with the repeater.
I'm not an expert on laws governing max watts repeaters can have.
buddrousa
What does you Radio Station License for the Frequency you have say?
Just a hint 100 Watts ERP is the Output Power out of the Duplexers Minus the Feed Loss Multiplied By the Gain of the Antenna Equals ERP.
That is why you need all the tools that a Radio Shop has to set the Frequency, to set the Power, to tune the Duplexers, and to check the Power and SWR. Not a Hobby Toy VNA Meter that sells for $50.
prcguy
A hobby VNA can be used to verify ports and give a good indication if its tuned to the correct frequency. A cheap VNA can sometimes do final tuning on a flat pack notch only or a 1/4 wave pass only duplexer depending on VNA dynamic range. They cannot tune an 85 to 120dB isolation duplexer, not enough dynamic range for that.
The instructions for verifying ports or tuning are too much to type here and there is probably a YouTube video that covers it.
davidgcet
is it working now, or totally unknown? if totally unknown then do NOT connect the repeater rx just yet. those sinclairs can dump power back out the rx port if badly out of tune and cause front end damage. this is also why you don't tune them under power, i've seen more than one blow out a receiver when someone tried to tweak it a little too much. if it works and you just think it could be better, then hire a pro to come check it out. there is more to it than just peaking the pass and dipping the notch.
BTW, it is possible to tune either side as high or low pass. it "should" be as marked but i have had to retune them opposite before when the plunger was pitted right at the desired spot so we flipped them to make them work. not for a customer, but several times for some of our own stuff.
That's what I'd do. Plug your SWR meter directly to the repeater TX output port and your antenna into the other side (leave the duplexer out of it for now). That'll tell you how much power is coming directly out of the repeater.
Then reconnect the duplexer to the repeater, low pass to your TX, high pass to the RX and connect the SWR meter to the antenna port. Connect the antenna to the other side of your SWR meter.
Then read the power output again.
The specs say that the duplexer should have around 1.5dB of loss. That's about 25% loss. So if your repeater was putting out 100 watts and you saw 75 watts or so out of the antenna port, then you'd know you had the duplexer connected correctly.
If the power output of the duplexer was zero, then you'd know you had it backwards.
I did this on one of our repeaters the other day just to check to see I had it all connected right. 10 watt repeater, 7.5 out of the duplexer.
It should. If it wasn't low, you'd have reflected power that would throw your readings off. That's close enough for testing.
You don't want to do that. But I'd be surprised if your repeater was putting out more than 100 watts. What kind is it?
FreddyM
Saskatoon,Canada
It is a Kenwood TKR-D710.
I forgot to mention that the repeater was programmed by the company it was bought from so the output power would have been set correctly according to the laws governing repeater output power in Canada.
I did go online to try to find what that law states but seeing as I'm not quite sure what I'm looking for I didn't find it.
As for the duplexer, it was tuned as well by the same company. I did try to be gently when moving it but from what I learned online they are fairly fragile.
At this point what I'm trying to do is figure out if I am hooking the interconnecting the repeater and the duplexer correctly.
With the above information, would you still go ahead and check it this way?
Once I figure out the correct termination setup what I would like to do than is see if the duplexer tuning is grossly out with the VNA meter.
Again I did watch some youtube videos and I did get the message that I can't tune the the duplexer with the VNA meter but it seems like I could get an idea how the tuning is.
I paid 75 for it.
TKR-D710 is capable of 50 watts. It is possible to set them lower.
Your license should state what your maximum Transmitter Power Output is, and/or your Effective Radiated Power.
Yes. Reading the power output directly off the back of the repeater with the duplexer removed and the other side of your watt meter connected to a 50Ω dummy load or at least a properly tuned antenna should give you an idea of what the repeater is putting out.
Then, reinstall the duplexer and test power on the antenna port as I mentioned above. You'll either see something around 35 watts if things are hooked up correctly. If you see 0 watts, then it's hooked up backwards.
FreddyM
Saskatoon,Canada
Okay Thank's for the information.
I need to get some coax adapters and than I will check it out.
I will report back how it turned out for me.
Pittsboro IN
Another test is to use a male to male N adapter and put your Wattmeter on the repeater output to measure power, then use your jumper to see how much line loss it has. It's not duplexer related but does show the quality of your jumper and cable from the output port to the duplexer.
I had an RG-142 jumper from the repeater to a transmitter combiner flake out and cause what sounded like intermod.
FreddyM
Saskatoon,Canada
I checked it out and I got 23 watts out of the repeater and 16 watts out of the duplexer.
Does that seem right?
The repeater and duplexer were hooked up backward and since I corrected that our coverage is a lot better.
My problem now is I can hear the repeater on my mobile but from the same spot I couldn't transmit to it.
With my watt meter and nano vna meter are there some test I could do on the RX side of the duplexer and repeater to see if that is working correctly.
You are getting into the area where you need a proper set of test equipment to align the duplexer (sounds like it's a bit off) and test everything else.
This is where it pays to have a professional look at it. You are beyond what you can do with your current tools, and the right tools are going to be very, very expensive.
prcguy
23w is 13.61dBw and 16w is 12.04dBw. The difference is 1.57dB loss which sounds a little high for a four cavity but not drastically high. Or it could be what you get trying to push a four cavity to work on a 600 KHz split.
davidgcet
also keep in mind you may hear a repeater a lot further out than you can talk back to it. as said above, if it is not working right or how you think it should then it is time to call in a pro with the right tools to check it all.
FreddyM
Saskatoon,Canada
Does you radio work closer to the repeater?
I was within 600 feet of the repeater with one radio and 20 miles out with another and I was communicating.(Receiving and transmitting)
Than I moved too another location with the one that was 20 miles out( closer but kind of a hollow) and I could hear the repeater but I couldn't reach it.
The radios are kenwood 7302 FM VHF and using tram 1159 antanaes.
Why is it that I can hear the repeater a lot further out than I can talk back to it?
The repeater is only transmitting at 16 watts( after the duplexer) and my radio is transmitting at 30 watts.
Is it all in the antanae?
The swr on all antanaes is around 1/1.2
As most of you have guessed I don't know much about radios so explain what that means.
As for the guy's saying I should get a pro to look at it, that's very good advice and in the end that's what I'll probably have to do.
That sounds pretty good.
Yes, the antennas make a huge difference. There may be other issues with duplexer tuning, but being in a hollow and it not making it back to the repeater at nearly 20 miles doesn't sound too bad to me. If you are concerned, get a professional to come out and tweak upon the duplexer with the right tools.
If you really want to squeeze every last inch out of the coverage, that's what you should do. But if it's doing what you want right now, then it may fall into the "good enough" category. On site tech time won't be inexpensive. But they will have the right tools and may be able to identify other possible issues. SWR isn't the final authority in antenna system performance.
FreddyM
Saskatoon,Canada
I may have missed this but I will ask.
1. How high is the Repeater Antenna?
2. What type of Repeater Antenna are you using?
3. What type of Feedline are you using?
Repeater antenna is at 35 feet, it is a sinclair SG217SF2SNM and there is around 80 feet of LMR400 coax going to the antenna.
