Hi guys. I'm going to be buying a digital scanner here in the next few weeks and I'm torn between whether to get the 396 or the 500.
They both look like good scanners and since the price is comparable, that really isn't a factor. What I'm really interested in is your guys' opinions about your units. I live in Greeley and commute down to the DTC every day. Right now I've got an old SC150 that I mainly use to listen to Boulder and Gilpin county. Since I know that CSP is on the state trunked system, Greeley and most of Weld county are on 800 digital systems, and most of the other places inbetween home and work are on digital systems, it's pretty much a no brainer to upgrade.
So, I'd like to hear your opinions on what you think of either set that you have. If you have both, I'd like to hear if you notice any shortcomings reception-wise with either. I'm not really interested in the debate over the dynamic memory vs. OOP stuff, because either interface's learning curve would be about equal for me, coming from a simple "insert frequency and go" type system.
Since I got a *very* nice end of year bonus, if the comments don't really sway me one direction or the other, I'm tempted to pick up one of each and try them both. My concern is whether I would be able to turn around the "loser" unit and sell it for close to what I pay for it. I would really only end up keeping one unit, but I figure if I try them both out for about 2-3 months, I'll be able to choose between one or the other. I can't really see taking too big of a loss in sale price on a scanner that won't have any cosmetic issues, and only really be gently used at worst.
I've seen comments about places selling eval units, is there any place you can recommend that might be able to help out in this situation?
Antennas...something else I'd like to get opinions on. Are the stock units working well for you guys, or do you have any recommendations on upgrades? When I'm using my scanner in the truck, I have it connected to one of those glass mounted antennas from Radio Hack (double-sided stick tape type), but if I'm using it outside of the vehicle, will the stock antenna hold it's own?
I'm not sure if I should cross-post in the GRE or Uniden forums to get a more broad-based opinion, because I'm really interested in what you local guys have to say before going to others that are in regions that may not really be conducive to how the systems respond to monitoring here.
Any help and guidance would be much appreciated. Cheers and Merry Christmas!
-- B
-- B
