K4EET
Chaplain
Very good and wise choice IMHO. I think you will be glad that you went the more expensive route up-front in the long run. Enjoy!<snip> I'm decided n the 536
Cheers! Dave
You will need a cable to connect with the incoming scanner. If it is an earlier model than the 325P2 or 996P2, it would use the same cable that the 15X uses. If it is a 325P2 or 996P2, then the cable you need is a basic Mini USB cable. (The 536HP, as well as the 436HP, SDS100 & SDS200, also use a Mini USB.)well apparently from what I was told the scanner or 2nd scanner as I got mine coming, runs on the free scan, so I am curious how I save the frequencies and upload it to the scanner when the time comes, I played with free scan, seems more complicated then sentienal
Yep, my bad.SDS100 uses a mini USB. SDS200 programming cable is micro USB.
A mini USB cable comes with the BCD536HP. You may not need any other cables.so i buy a cable on amazon or another shop online, ok i got it.
Without putting an antenna analyzer on it while it the antenna is mounted to an adequately sized sheet of metal, it is hard to tell how good it will work at the various frequencies between 20 MHz and 1.3 GHz. Quite honestly, a metal coat hanger might receive just as good on the band(s) that you want to monitor in. Note that the key words here are where you want to monitor. If I were you, I would write down the frequencies/bands that you want to specifically monitor in and purchase an antenna with gain around the frequencies/band that you are primarily interested in. After I post this and I get some coffee to wake up, I'll look over your posts and see if I can tell if there is a particular band to focus on. I think you can do a lot better than with the antenna that you have mentioned...<snip>
will this work if I buy it?
Not sure exactly where you are and I don't know where the Whatcom County communications towers are located so I used a "somewhat best case" scenario since both the Bellingham International Airport (BLI) and the Friday Harbor Airport (FRD) are fairly close to the water's edge. Using that criteria, we find:<snip> I am planning to buy this and set it near my window so I can see if I can get all the way to Skagit or Whatcom countries <snip>
In your case, the value of "h" is near zero which means the horizon is also near zero, which means (relatively speaking) near zero probability of hearing those other two county communications systems. When you will start to have a glimmer of a hope of hearing something is when you get a roof-top antenna (what @tvengr mentioned) on a mast or small tower and the transmit antenna in Skagit County or Whatcom County that is nearest your location is on a tower at the 350 foot to 400 foot Above Ground Level (AGL). Then you might have a fighting chance.Assuming no atmospheric refraction and a spherical Earth with radius R=6,371 kilometres (3,959 mi):
- For an observer standing on the ground with h = 1.70 metres (5 ft 7 in), the horizon is at a distance of 4.7 kilometres (2.9 mi).
- For an observer standing on the ground with h = 2 metres (6 ft 7 in), the horizon is at a distance of 5 kilometres (3.1 mi).
- For an observer standing on a hill or tower 30 metres (98 ft) above sea level, the horizon is at a distance of 19.6 kilometres (12.2 mi).
- For an observer standing on a hill or tower 100 metres (330 ft) above sea level, the horizon is at a distance of 36 kilometres (22 mi).
Well... Will it receive something? Probably. Will it work the way that you want it to? Probably not. @wtp gave you a good response. I could chop that antenna into itsy-bitsy little pieces by dissecting it to show you why it is a bad choice. The same antenna elsewhere on Amazon says it uses RG-174 coax which is quite lossy at 800 MHz and above. Has a VSWR<2:1 -- at what frequency? Certainly not the 20 MHz to 1.3 GHz spread. The list goes on and on. You can do better.
I have a favorites list for San Juan, Skagit, and Whatcom Counties with WA State Patrol and the VHF marine band. It includes the WA State DOT trunked system which has 2 talkgroups for the ferries. Let me know if you are interested and I will attach it so that you can import it into Sentinel.im 1 mile on top of the hill on tucker avenue, 1 mile from the ferry terminal.
