So my bother finally asked me a question, he wanted to know more about the following as hes intrested in buying these but was curious if you have any info on the models.
1. uniden bc365crs
2.uniden bc355n
3.bcd996p2
4.bcd325p2
he doesn't want the 436 or 536 hp however he does like the SDS 100 or 200 but cannot afford them, so he wanted to start somewhere since he has now an income he wants to expand his hobby, any suggestions?
Eaton and Ingham Counties
While the BC365CRS and BC355N might be acceptable to the conventional channels in
your area, if these are suggestions for your brother, neither would be useful to him in Michigan. Both
Eaton &
Ingham counties, in Michigan, use the statewide
MPSCS system, which is digital. Neither if those models are capable of monitoring digital signals, and neither can be programmed for trunked systems.
The 325P2 & 996P2 are capable of receiving digital trunked systems, either P25 Phase I or Phase II. His statewide system is capable of Phase II, but for now, it appears they are using Phase I. The MPSCS system's sites in both Eaton & Ingham counties are simulcast, which can be a problem for scanners other than the SDS series. While the 325P2, as well as 996P2, can receive the Phase I talkgroups on the system, neither of them handle simulcast well. The 436HP and 536KP are somewhat better at simulcast than the P2 scanners, but they are not bulletproof. The 436HP & 536HP are database scanners, which means that they have the entire RadioReference database stored on memory cards, and can be used to scan using the main database, along with a location and range, without a lot of programming. Long term, creating Favorites lists for just what is wanted to be monitored is more satisfactory than relying on the database, and trying to juggle location, range, & service types to narrow down what your hearing.
Simulcast systems can be a pain, but is very dependent on your actual location. If you are at the 'right spot', where terrain (hills & low spots). a cluster of taller buildings, or something in your house (metal siding or foil backed insulation in the walls) leads to the scanner only receiving a single sub-site of the simulcast, then either of the P2 or x36HP scanners might work satisfactorily. Scanning from a fixed location, such as a residence, you might be able to use a directional antenna to narrow your reception down to a single site. But there is no guarantee as to whether any of these methods might work. Reception can be so location specific that moving the scanner a foot or more to a different spot in the house may make the difference between reception, or only hearing a garbled mess, if anything at all. Of course, those potential work-arounds are only effective when at a fixed location. If you are out and about, with the scanner in your vehicle, then you may well lose the system entirely.
